As suggested above, you should try to find all your own parts and save some money as much as you can. Use eBay to find all those cheap copy fuel pumps, plenums and exhaust manifolds.
That way they can charge you the time the job takes, plus the time to tidy up or repair the cheap part, charge you to replace the part when it fails and charge you all the labour again to fix it.
You'll save heaps.
You'll save heaps.
:yes: best post ever
You'll save heaps.
This !!
Do it once, do it right !
It will cost you but it will be done properly.
You'll save heaps.
yeh no that's not goin to happen build it proply the 1st time.
Excellent to hear.
If you find cheaper prices for parts they are offering, maybe ask them if they'll match it.
I don't doubt the parts list will be appropriate for the power you want to make but there are a lot of things involved in a build like that. Do you really need that plenum?
Do they do all their own engines or are the built somewhere else? What kind of warranty do they offer on their work (inc the engine) if any at all.
What kind of gaurantee do they give that you'll make the quoted power. It's a lot of money to spend only to fall short of your goal
They recently did a nitto rb32 build for a customer with an r34 gtr and oh my God so so much power..best part was customer had unlimited budget so they were able to do things properly.. Car drives like stock but when you floor it, destroys the road under it haha.
I thought you had a HTA3586?, anyways cams are to big for a start... looks like
a lot of money for f**kall gain..you seem to like to spend money for no apparent reason(and no i am not having a go at you
just having cars and mates with similair setups..thats total and utter overkill for the turbos you want, K.I.S.S, is what you want to do
quality parts that will do the job asked with overdoing/overkill them...you will spend twice as much for no reason or reliability..
You REALLY need to decide what you want before you start...
cheers
Darren
Edited by jet_r31
You'll save heaps.
hahaha, thats doen't happen much..lol
cheers
darern
Just a quick one....I was reading through the list again and noticed you are only using 1000cc injectors and a pump that flows 400 L/min @ 60psi.
That pump will just scrape in at 650hp at the wheels on E85 so you should be ok for flow there but the injectors are really only good for 550hp on E85 so maybe you should ask them about 1600cc or 2000cc injectors instead?.
You can just bump the rail pressure up to make the injectors flow more but the pump will then flow less and it brings it closer to your 450kw margin. Just some food for thought anyway
to be honest I also thought they where on the smaller side if and when I Desideed to go E85 so yes bigger injectors I will get Edited by MRHD66
Honestly....I would develop a fantastic relationship with a workshop and get them to build the thing. Price sounds about right but its the things you can't put a dollar value to that are important. You take $1000 off the price somehow and eventually you will be paying $5000 back to them or someone else.
If and when? You're going to make 600hp at the wheels on 98? I applaud your courage
Can be done. Much safer on E85. The cubes should help but still.....
You'll save heaps.
lol, so glad I'm not in the automotive industry anymore. People think you're ripping them off if you charge them for the time you spend sourcing parts. Then they say you did a shit job when the parts they supply that you've never used turn to shit, assuming they even give you everything you need. They also expect you to take up the warranty with the companies they bought the parts from :thumbsup:
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
