Car failure... please. We're not all that simple and naive
Two identical crashes... IDENTICAL... one caused by this mysterious "problem on the left front corner", and the other driver error?
They may be able to kid the idiots in America and Italy, but I'd like to think we're all a little more sceptical here
Clearly Ferrari are trying to keep the pressure of him because he will crack under the media spotlight and ruin yet another constructors tilt for them
you could actually see the front left bouncing around a bit before the 2nd crash.
probably clipped a wall somewhere earlier and something broke.
That's where my one eye might obscure my opinion
So the question is... did it break because a component failed, or because he previously hit a wall/kerb a little too enthusiastically?
Given his history of utter hack-ary, i would agree with the clipped a wall theory
Its a bit unfair for merc to test in season. Even if they didnt gain any data etc from perelli (im sure they would have though) then its still 'x' amount of extra laps and experience on the tires. Im not sure if the merc test driver did the test or the race drivers, but either way still valuable
Didn't Pirelli say it wasn't on the current tyres, and that Mercedes did not know what tyre they were on at any time?
Tthey've also said right from the start that it was both current Mercedes drivers that did the testing - Rosberg and Hamilton.
Edited by hrd-hr30
hmm, yeah the Canada spec tyres weren't "current" at the time of the test were they?
Canada tyre changes have now been postponed to Silverstone/British GP, waiting on the outcome from this by the FIA.
My money is that the FIA will say Mercedes could have gained an advantage on those new updated tyres from this test, and rule that the tyres can't be changed to ensure no-one is disadvantaged.
My 2c is nothing will happen. Suspended sentence. Merc are too big a player as team and engine supplier so politics will get in the way of giving them the reaming they deserve (which is a shame as I am hoping to see Merc have a good few seasons)
They didnt know what tyres there were running, but you know it makes perfect sense for the Mercs to have run a few of the current compounds against some of the compounds proposed for introduction this season. The engineers are not dumb and would have had a good idea within a few laps of what tyres they were on.
There is also the likelihood that some compounds for next year could have been run but only very initial test as they are having troubles with current tyres, need to get their heads around the changed tyre before they spend too much time worrying about next years tyres when testing with an NA engine vs turbo engine etc etc isnt going to tell them a lot
... of course if they continue to employ drivers like Malappropriate, they may as well just use a turbo diesel from a light commercial vehicle
What choice do they have. Look at how much money Lotus lost last year. If Williams did that they would disapper in a heartbeat. Lets hope their new CEO will be better than the last.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
