Jarno Trulli intends suing his former team boss Tony Fernandes after the Caterham owner failed to pay him out.
"I'm going to sue Fernandes, because he owes me a lot of money," the Italian told Autospirit.
"My career in Formula One ended because I agreed to give up my place, because I was assured that the team would fulfill its contractual obligations.
"To date, this has not occurred."
http://www.planetf1.com/driver/18227/8748685/Trulli-set-to-sue-Fernandes
its also run in the most lackadaisical affair you could possibly imagine
you can jump fences, break into just about any high priced grandstand, stand literally next to the track and almost nobody will stop you
not to mention, generally speaking, everybody is so well presented and nice
Kamui Kobayashi is keen to return to F1 next season but if he doesn't has promised to refund all those who sponsored him.
"I want to come back to Formula one next year," crash.net reports him as having said, "and there is one thing I want to be clear about 'Kamui Support'.
"The donations of Kamui Support have not been used at all this year, because this was purely for F1 seat.
"If I don't need to use them for next year's F1 seat, I want to return all to [those] whom made donation."
http://www.planetf1.com/driver/18227/8755336/Kobayashi-chasing-2014-comeback
the whole merc testing row seems like fairly big news
team cheater are also embroiled in the scandal
seems like everybody will walk away fairly unscathed
Which will be a surprise to no one. Team cheater get away with any and everything. Cause cheaters are important to the sport or something. Maybe the FIA shoud have asked them if the rule should be applied? They used to do that in the good old days.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
