sweet gig for Mark
It is for Mark. Although I am sad to hear about Mark's retirement from F1 (big fan), I am pleased to hear he will remain in high level racing.
Le Mans et la serie endurance is very much on my watch list and rather exciting to know Mark will now be part of it.
Mixed feelings about how he announced it. Good on him for being "no notice Webber" and doing it on his terms. But six for his mechanics and those close to him in the team to not hear it from him directly.
I suspect the way he announced it has done him no favours with regards to trying to bag a few more GPs before year is out. Oh well...have to decide whether I go to Singapore, India or Japan. Most likely Japan...over India and street races suck for access and spectating!
Well I am off to Singapore - but Japan may have been a better choice. Anyway one last dose of atmo motors and MW.
Post race concert in Singapore? Fkn Justin fkn Beeber. FFS the fkrs fkn fkd.
Q&A with mark webber
Following the announcement that Mark Webber has signed with Porsche to join their WEC and Le Mans 24 Hr team campaign in 2014 and beyond, www.markwebber.com asked him the burning questions:
Why have you made the decision to join Porsche in the WEC at the end of the season?
MW: The timing is perfect to join a fresh programme. It’s a sensational challenge and opportunity for my future to work with one of the most famous marques in motorsport.
How do you feel about returning to Le Mans after what happened in 1999?
MW: I accept that motor racing is dangerous but Le Mans is one of the most famous circuits in the world and to be honest, I still see it as unfinished business and I want to do well there. Le Mans can be cruel as we’ve just seen, but it’s incredibly rewarding and that’s part of the allure.
Did the events of the Malaysian GP (or other well documented inter-team incidents) influence your decision/make your mind up?
MW: No, I’ve had a personal plan and I’ve stuck to it. This is the next chapter.
Were you pressured or encouraged to leave RBR by the team or was it purely your decision?
MW: I never asked the team for more work but I’ve remained in touch with Dietrich Mateschitz over the last six to eight months and he’s been absolute quality for me. Going forward I will remain tightly inside the Red Bull family, working with the brand, and watching and supporting fellow Red Bull athletes push the boundaries.
You are one of the oldest drivers on the grid, has your age affected your driving and was this a consideration in your decision to leave?
MW: Of course you want to do your whole F1 career at the age of 25. Ask any sportsman or woman in their mid to late thirties and they will tell you that things don’t become any easier. That’s just a fact of professional sport.
Did you have options to stay in F1?
MW: Yes but since Formula One as a category wasn’t on my radar for 2014, they weren’t a consideration for me.
Will you rule out a return to F1 should another opportunity present itself in the future?
MW: I’d say it’s extremely unlikely, particularly given the new direction the category is going in. You would be out of touch very quickly.
Finally, what will miss about Formula One?
MW: I realise F1 is seen as the absolute pinnacle of motorsport and I’ve worked with some incredible people, in particular Adrian Newey. I’ve driven in some of the toughest and most challenging conditions and circuits, and against some incredible drivers which I’ll continue to do until the end of the year. Will I miss some of this? Yes, of course, but time doesn’t stand still for anyone and it’s time to move on to my next challenge.
http://www.markwebber.com/on-the-track-news/2013-season/mark-webber-qa-2014-and-beyond/
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
