Sorry Paul I can't remember Matts setup but unless the -5s where setup properly with all the right breathing mods then that is a miss leading result as the single would have custom manifold, custom intake, custom dump and front pipe that are purely designed to make that turbo work to its most effective efficiency
So unless the same was done for the -5s its not a fair comparison
Arh yes Micko, but in your opinion the lancer is a mans car too lol :P
  • Like 1
Take matty from WA's experience. Twin -5's on a 3.0 and went to a 8374/0.92 internally gate single. The EFR was back to peak boost levels in a 1/3rd of the time the twins took (Motec logs), made more power everywhere also.
However, it would be interesting to compare something like the 8374 EFR to say twin 6258 EFR's.
Is there any graphs of this car, would be interesting to compare to mine.
Meh... Come for a run in either of my laggy twins a see what lag isn't :yes:
Do you have a build thread or dyno/boost sheets?
I'd be reasonably confident I would see full boost earlier than a 600whp pair of low mount twins :)
I do, in the RB30 dyno thread, but the RPM scale isn't correct and like I said earlier, dynos lie or/and can be made to lie, you want a true idea/indecation of response look at ET v MPH :thumbsup:
This is way I go to the drags after I do a mod cause
ET is a good indication of setup
MPH is good indication of power to weight
ET v MPH is a good indication of response
And while all three will effect each other, when looked at each individually you get a good idea of it
Edit, Scott also said it shows it ramp up later then reality cause he had to do something about it spinning all 4 on the dyno, I'm not sure what he did just he said it is slower to show ramping up :/
  • Like 1
Hahaha i remember a certain somebody getting out of my "mans car" giggling like a little school girl after he'd driven it with the stock turbo and a dodgy E85 choon so it couldn't of been that bad? :P
The 2.6L 8374 equipped missle i went in today certainly sealed the deal with everybody that went in it.. Including some pretty hardcore #twinturboGTR4lyf mofos! They even buried the notion of needing 2 turbos for response in this wonderful age of lightweight billet materials and black magic aerodynamics that make 1 turbocharger enough to tear ya face off from 4000rpm to redline (in 2nd gear) from a 800hp turbo :)
Once you have been enlightened Micky the possibilities are endless :P
While i can see you have a "purist approach" to your GTR's (which i respect) as every GTR I have been in and driven has been a twin turbo from Jez's car to piggaz car to my dads car!
Which have all been amazing dont get me wrong!
But remove that lil pipe that says twin turbo and it moves you into this marvelous era of modern day turbochargers :)
Drive 1 and be enlightened in 2015 mate :)
  • Like 1
Like x1000 :)
Lol, the difference between a girls car and a mans car is a girls car leave you giggling like a school girl and mans car make you stand infront of it scared to unlock it, my old turboed Corolla always left me giggling when I would punch it :D
I have said this for quite a while now, the big singles have the tech edge ATM and its doubtfull someone will make direct bolton twins for the RB26 setups, though a set of 6258s in direct bolt on would be nice on a 3.0, my theory of tech for tech twins are better still remains and always will cause I have seen it first hand
What can you do to that setup to optimise it?
The stock manifolds are fine, we both use them, I believe it ran pods as it was a 32. The exhaust wasn't small. It's pretty much a no expense spared car.
It was simply take the -5's off and put the EFR on. Belts it every way possible. Low end grunt, too end power, comes on earlier and back on sooner between gears.
If you could do a back to back between twin EFR's and the single to see the difference, I think that would be interesting but comparing it to what realistically is dinosaur twins (-9's,-5's,2530's,RS's, the trust things) the EFR would belt the shit out of them. This car that I went in yesterday was cracking gates at 4200 on a nugget 2.6 in second gear. -9's wouldn't do that yet the 8374 would supply Atleast another 100 kw of grunt. Between gear, forget it. It was like the gates shut at all. As soon as the clutch was let back out, it was making a anti social noise again.
Twins for an rb26 are stuck in 10yr old technology and always will be! For the simple fact no aftermarket suppliers care about them anymore as the engine isnt being produced anymore and never will be.
All of their r&d is being thrown at cars like the r35, evoX (for now), new wrx and of corse universal singles as that will always be their biggest market due to the fact they can be made to fit everything.
But my Gtr will always be twin turbo even knowing the turbos are old tech and getting older every year, but I also have plans to try and bring them closer to this new technology and if it works should be a great kit, if not......well at least I tried something different
R35 seems to do ok on twins :)
Different configuration being a v6, although, if the single really is leaps ahead of a twin setup...I wonder if there will be a single kit for the mighty 35? I doubt it hehe
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
