I have Alcon front kit with 343 mm rotors, but thinking about these kits http://www.jdl-brakes.com/special-offer-alcon-adv-extreme-brake-kit-front-and-rear-nissan-skyline-r32-r33-r34-gtr.html What wheel do I need to clear 6 pistons calipers with 365 mm rotors ? 18x9 +15 would be ok ?
What wheels specifically? A R34 GTR rim won't really work as any small stone that gets caught between the caliper and wheel will get caught for example.
At JDL website, you can download caliper profile, and check clearance with your wheels : http://www.jdl-brakes.com/alcon-adv-extreme-brake-kit-front-6-pot-o365x32-nissan-skyline-r32-r33-r34-gtr.html
From my experience 9x18 ET15 will work ok with Alcon 6 piston caliper.
Will depend on the type of rim, I used the template and it did not clear my 18x10 +15 work meisters deep dish
Which model of work meisters do you have ?
My brother-in-law, has 18x9.5 +23 meisters on his R33GTR, and there is still 4-5 mm of clearance. Did you use template properly ?
Did you mean 6 pot Alcon kit as here : http://www.jdl-brakes.com/alcon-adv-extreme-brake-kit-front-6-pot-o365x32-nissan-skyline-r32-r33-r34-gtr.html
It would all depend on the disk faces of the rim:
R disk for: big caliper clearance.
A disk for: meh calipers.
O disk for: who cares about stopping, take the calipers off and get as much diiiiiish as you can.
mine are O disk, due to dish it tapers back on the back of the rim which fouls the calipers
Is the ATTKD brake kit from just jap the same product as D2's?
Also, UAS has a few interesting big brake kits under $3k
http://nismo.com.au/pricelists/pricelist_gtrbrakes.htm
Are they worthwhile upgrades? Namely the AP Racing upgrade
Which one is the 3k? Most prices appear to be either front or rear kits only not a set, may as well jump on the D2 groupbuy
Cheers thanks for the feedback
Will these fit under a lmgt4 18 x 9.5 +12? and yeah ive seen the template but im a lazy bastard lol
6CF28A3A-64B1-4D3B-85ED-AC1446AD8C5F-147
Yep. Here they are on mine (Using GTR JOEY's LM's at 18 x 9.5 + 12). They don't really fit under a R34 GTR wheel. Yes the wheel will go on, but there is so little room that little stones get caught between the caliper and the wheel.
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
