So.. trying to find someone reliable/affordable to machine dogbones etc. for my V8 Supercar alcons is proving to be a bit challenging. (My calipers https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash4/1094662_10153125748100301_2119536866_o.jpg )
The Alcon extremes (http://www.jdl-brakes.com/alcon-adv-extreme-brake-kit-front-6-pot-o365x32-nissan-skyline-r32-r33-r34-gtr.html) appear to be a much easier upgrade as they come with all the parts ready to install.
Aside from running a smaller rotor, what are the main differences between this kit and the calipers I already own?
Brakes are for a 32 GTR track car, mainly doing sprints.
Well the kit you have allows you to run a bigger rotor with better wheel clearance. It is lighter than the Advantage caliper. But those things are all bee's d1ck things. The one main reason why your calipers are superior is the titanium pistons work waaay better at keeping the heat from the pad out of the brake fluid.
But again, the Advantage kit is pretty damn competent on most track GTRs. Especially if you are going to get stung for $600 for a pair of radial mounts. $800-1000 for the hats and bobbins to work with the V8 Supercar rotor...then lines and pads. Buying $1500 calipers can quickly add up to serious money if you dont have a line on good combination rotors and hats.
If you are going to run those calipers I personally would go brab some off the shelf 380x35mm rotors, either aftermarket or off an R35 and then just pay the money for the radial mounts
Lug mount, is your traditional mounting style that comes standard. Radial mount calipers differ, in that the caliper bolts go through the top of the caliper to the upright. It's regarded as the better, stiffer way to mount the calipers. You can get radial mount dogbones.
So if I run R35 rotors I don't need custom top hats & bobbins?
Is a radial mount the same thing as a dogbone? Who does them for $600?
You can run whatever hat/rotor combination you like but Troys point is that the replacement cost of the rotor (or hat and rotor) is one of the big considerations in its selection. By using a part from a certain vehicle (eg R35) you are getting a component that will be made by a number of different manufacturers which will help keep the price down. Eg Project Mu 324x30 hatted rotor is thereabout of a grand. The 345x32 is double that. The other cost consideration is the price of a pad. same story there. Buy an orphan pattern and you will get screwed every time you need pads.
Yes a dogbone and a radial mount are, essentially the same thing. A radial mount uses bolts that align radially to bolt up the calliper, a dogbone has locating bolts at 90 degrees to that - hence the same as it looks a bit like a dogbone. You need to find a machine shop and give them some drawings. I have tried and utterly failed to find someone for this sort of thing. But this is a one off cost, not a recurring one.
I use Alcon front and rear kit for one year on my R34 GTR. So far 12 track events, and these brakes are best mods I've ever done.
Some 17s ... not all 17s. Based on my experience with 343mm setup and CSC calipers, AP CP5555 and F40/50 calipers and 343mm rotors thinhs like AVS Model 6, Work XD9s, 57 Gram Lights, CE28s etc wont fit inside 17" wheels. Teh CE28s fitted but not enough clearance
Things like Weds, LM GT4s, TE37s etc will do it easy. I have not tried them but people seem to enjoy some luck with Enkei RP-F1s etc
If you want to guarantee fitment inside a 17" wheel then you need to go 332mm rotor
Have just ordered RS 19's for the front for the advantage calipers on a R33 GTR. Will report back.... Anything would be better than the 2500's.
Did you mean DS2500 or DS Performance ? I thought they come with DS Performance http://www.jdl-brakes.com/special-offer-alcon-adv-extreme-brake-kit-front-and-rear-nissan-skyline-r32-r33-r34-gtr.html
DS Performance pads are better than I thought. When mine kit came, I was ready to put RS29 for first use, but my mechanic put original pads ( DS-P ) by mistake. I can say, for normal street use, they are not bad. I haven't tested them on track, but if someone use car on street only, DS Performance are not bad choice.
I heard that Alcon kits what we buy, are street legal in Europe, that's why they come with street legal pads.
You could be right.
Either way, the pads that the kit comes with are junk.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
