They aren't too bad but don't let servicing be a deciding factor in purchasing.
I've seen alcons and many other brands literally black from heat and they are still perfectly serviceable internally.
The callipers will outlast your ownership of them if they are kept in working order.
6CF28A3A-64B1-4D3B-85ED-AC1446AD8C5F-147
Yep. Here they are on mine (Using GTR JOEY's LM's at 18 x 9.5 + 12). They don't really fit under a R34 GTR wheel. Yes the wheel will go on, but there is so little room that little stones get caught between the caliper and the wheel.
LOL GTR Joey bought those rims from me last year!! damn they look sexy on R33s. Have they been refinished yet?
How much repair parts for Alcon brake kits like calipers seals, pistons etc. ?
Contact these guys www.motorsportbrakes.com.au and they have repair kits and a large range of pads on the shelf specific to these alcon kits. Speak to Marty his a very helpful guy
Nah mate, as you sent them to him. The tyres on the are awful! lol. I think he will do them when he puts the semi's on. That should be very soon.
Ye the tyres were rubbish that's why I gave them away with the rims :P
Dim looks like I'm going to have to go with your setup. There's only so much playing around with the stock brakes you can do - at the end of the day, for any sort of non-street driving, they're simply just sh!t....
Just read a few pages back that these alcon's are more of a 'street' application rather than heavy duty track calipers. What's the major difference with them and I suppose the 'normal' alcon's? Would they perform better/worse than the D2/ATTKD brakes?
From what I've seen - exactly the same.
After 10,000kms, 3 track events and a tarmac rally event - my rotors were in great condition with DS2500 pads. DS3000 will eat a rotor if you use them heavily, and also by the same token, if you do not get them up to temp.
Just because one person tracks their car doesn't mean that they are using the brakes properly or driving the car 100% despite them thinking they probably are, your best selecting brakes from your budget and personal skill level than what others are using.
90% of novice drivers would not notice the difference between these basic Alcon kits and the Chinese kits IF they are fitted with the same pads.
In fact most wouldn't even notice the difference between a set of Supercar alcons and D2's with the same pads.
100% agree.
My car - D2, a mates car - Alcon... I couldn't notice a difference other than his brake pedal was slightly firmer than mine, but that could just be brake fluid/bleeding as I'd not done mine for a good 6 months.
Yeah go for it man! You wont regret it. The difference is like night and day compared to the stock brakes
I am very happy with my Alcon Advantage Extremes that I got from Dan at JDL. I must admit though I'm not a huge fan of the DS2500 pads that they come with, Not enough initial bite for my liking. You can order them with "Track Pads" but I'm unsure if they are the RS29 Pagids that are supplied with the bigger Alcon sets for the R35.
I might try a set of Carbon Tech XD10's
Yeah i didnt even bother with the stock pads it came with. Apparantly there not even a 2500 equivelant so i went with some pmu clubsports up front and 2500 at the rear. With everyone buying from jdl through this thread alone we probably could have organised a group buy pretty easily lol
I may be interested in purchasing a set - front and rears 365mm/350mm. Will look at getting PMU pads. Was thinking initially to buy the whole brake kit from PMU.
Get a few peeps onto this and maybe get a awesome deal!
Edited by vspecIInur
I've sent you message
Hey mate, Can you give me the part numbers for the PMU pads you fitted to the Alcons? I'm struggling to find a pad supplier with pads to fit. I emailed Carbotech and they don't have anything on the shelf to fit.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
