id be buying the parts secondhand, aim is mostly some extra bottem end torque, used as a daily, would like a similar setup to say a VL turbo where theres no intercoolers or fancy manifolds..
Does the following sound realistic: assuming 6 or 7psi like a VL turbo would run
secondhand Gt3082/gt3076/gt3540 for $1000
walbro pump $160
possibly fabricate own manifold and short dump 3inch $ 800
some kind of chip/remap of computer $1000 using a fuel reg and stock injectors
bought car as a repairable write off for $1200, just needs some work with the front where the bumper fits, apart from that its very nice and is dual fuel and looked after so would be an nice project for a torquey daily driver..
thoughts anyone?
Edited by SliverS2
plenty of people have done turboed falcons (from ea through to au). 200kw is a very reasonable goal too. i wouldn't be suprised if it was higher though.
the biggest costs will be the ecu, tuning, turbo, piping (exhaust and cooler piping), cooler and setting up oil and water feeds to the turbo. and if you don't have a lsd, you might want to think of sorting that out too. the sort of torque that a 4L NA+T puts out will result in lots of wheelspin from an open diff.
Probably cheaper to sell it and get a ba xr6t...
ive heard alot of reliability issues with ba models and extra weight, and also an au would be unique so with the very small cost so far, a turbo conversion would be interesting, not for drag racing but just smooth torque for daily low revs stuff, be nice to hear a 3076 at work under there... have seen stock ba xr6 injectors, manifolds and dump for very cheap, makes it an attractive prospect, manifold would need some modifying though,
Geetee- thanks mate, id take that turbo, but just at planning/considering stage..
Edited by SliverS2
fordmods.com
A bit of info there.
thanks, some good info there
most falcons seem to gt3582's upward, i wonder if a gt3076 with a .82 or 1.06 would work well, as id like the turbo to be able to start pulling pretty much straight off the line with the auto like a VL would ,
also from what ive read the stock computer uses a map sensor so it may run safely on low boost, but a chip probably a good idea
Im not a fan of supercharging, i like hear turbo spooling noises and the sudden surge of torque comming onto boost compared to the linear delivery of the supercharger..
Edited by SliverS2
Ive git one in my driveway, remember xr6's have the tickford motor which is higher comp, This one is auto with a built box(the stocker didnt last long) running a 1.06 twin scroll gt35r, i think a 3076 would be fine as long as you ran a 1.06 housing. What are your plans for the dual fuel that would be the biggest issue, but you could put gas injection on it whaich runs its own ecu, just be limited with HP, dont want to end up spending 10K to get the whole thing done
well its a sprint gas system so i dont know how it works, wether it part of the petrol computer of seperate, i know it runs petrol first then after it warms up a bit it switches to gas if selected for gas ,( has a switch for gas/fuel), might need a computer that can handle two maps and have it tuned with two maps?
i really want to make it a low budget setup, $3500 max.. all second hand parts and do fab work myself if i can.. gas injection isnt really an option, i wonder if it could run the turbo on say upto 5psi and then switch for upto 8-10psi, or maybe the gas map would have reduced timing.. certainly throws a spanner in the works
how does the tickford respond the the gt35? is it laggy at all
Edited by SliverS2
you can get kits from snort performance for a reasonable price and they come with pretty well everything.
http://www.snortperformance.com/index.php?option=com_content&view=category&layout=blog&id=9&Itemid=9
No need for expensive manifolds.
Just buy a flange and have it properly welded to the original manifold and make the exhaust to suit. Fab up a bracket to support the turbos weight.
Grab the oil feed from the pressure switch port.
Drain back to the sump obviously. (Sumps not hard to remove of the old XR6's)
Water lines from the heater hoses
Run it with a factory BA cooler and make up some piping to suit.
Not long ago I did a bolt on turbo conversion to a dedicated LPG FG falcon. It made as much power on LPG as any other stock XR6T I've seen. If did require upgraded gas injectors and three LPG pump units with an aftermarket control unit.
Do your research about performace LPG systems, there is massive amounts of performance parts and injectors etc out there.
None of its cheap but the results are interesting
Thanks, ive been browsing ebay and gumtree etc, seems the stock xr6 turbo gear is fairly cheap so shouldnt be too hard to make it a reality,
Im still wondering what turbo should be used, my options as i see it for a budget build are the following
Kando dynamics T67
Second hand garrett
Precision
To make it cheap as possible would need the stock dump to bolt straight up so i think that rules out the kando, and from what ive seen the precision turbos have a 5 bolt housing but looks like its only 0.63, the secondhand gt35's are bit of a gamble though
Any opinions/advice on what turbo selection? im thinking now it has to be a gt3540 spec , a kando with a 5bolt ford rear end would be ideal but dont think that exists?
Edited by AngryRBGTX
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
