Sorry Kyle. I must have sold my sapre cluster surround for the 32. Had a good look tonight :(
Upside tho, found lots of other R32 GTR interior/exterior parts :D Will post up all my spares after I clean my garage this weekend. Includes:
Awesome drivers side window, new brand name upper control arms, Ahstrays, Kick panels, Boot trim/panels, front mesh :ph34r: , Looks new Drivers/Passengers seat belts, 2 x New Kaixen hids with balasts, BMC, power steering pump, Great full interior carpet, Head unit and other stuff.
I had fun looking :w00t:
Cooma Diesel in Fyshwick is Garrets local rep
If they cant do it or get you what you want no-one can
I'm fairly certain ESP, Trojan, Autotech could order in what you want in the way of Garrets.
They all have the Garret poster - lol
WTB 2860-5 or -9 turbos!
just checking if i can get one local, cause im too lazy to buy interstate LOL
or does anyone know where in canberra i can get turbos balanced?
Check Kudos Motorsports prices on new trubs.
Andrews great to deal with
Have a look on atpturbo.com and Paul at street to track can usually get them delivered to your door for the price listed on there or slightly less depending on conversion rates at the time.
The only issue is the probably don't do them as a set of twins, but it can't hurt to ask Paul...
Edited by Mitcho_7
i agree he is an amazing seller healps you with any of your questions :)
picked up a set for cheaap haha,
anyone know or reccommend a place for the turbos to be balanced and checked?
(for my older turbos)
i also will need tune, i heard autotech is the only place in canberra that can do a nistune?
got board and ecu with a base map for the injectors and turbo, so just need the tune :)
anywhere else can do me a cheap nistune? :)
WTB R34 GTT Series 2 side mirror control panel knob thing...or even that whole panel with the window and door controls.
The little tabs/clips that hold it into the door panel have been snapped off when the power window was fixed, and now it pops out every now and then.
Not really a big problem but it kinda bugs me :angry:
Must be the Series 2 one though... it's a round knob control not the square one.
Bit of a long shot but if anyone can help me out please let me know!
Thanks,
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
