hi -
WTB RB25det head or 25 with a blown bottom end - only really want the top -
Hey mate,
I have a few lying around the shop if you want. Is there any preference on internals like cams or no cams or what... pm me
Does anyone have a suitable 5x114.3 17" rim to use as a spare? Anything really, but preferably 8" maybe 9" wide.
I figure it would be better to have a similar size spare rather than the good old yellow space saver. :yucky:
Is there POPO issues with this?
Cheers.
Rob.
Do you want to carry something as big/heavy as a full spare around with you? The space saver is bad enough. TBH I have no idea why I haven't taken mine out yet... That should be one of my next "things you've done to your car lately" entries.... :)
You never know when you'll need the spare....however I knew exactly when I was going to USE that space saver - NEVER. I'd sooner pay to be towed than drive on that piece of shit lol (yes I know this is a silly way to look at it)
No way, that's my plan!
Cheers.
Rob.
I have a random 17x8 inch rim, it's an advan rim.
I got three advan rims with my car (i assume the other was busted) so youre welcome to take the odd one out for a small fee.
Edited by Mitcho_7
I friggen hate Sydney!!! Took me 2.5 hour to drive from Sydney cbd to St Marys. It was 1500 and a parking lot. Do Sydney people work what were alk those people doing on the road at 1500!!!
Rant over...for now.
i feel you.
even at 2am, sooo much traffic now.
wasnt this bad 3yrs ago even.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
