Another place for northsiders is Skylines Performance..... The boys are real pro's and as the name says they specialise in skylines and have built and worked on some very tough cars, and phil has worked on and knows everything about skylines since the r30...phone number is 62550200.... But for full on engine rebuilds and the like chasing big hp, the man is jake... Jakes Performance on 6255 4545 (he doesnt do regualr service stuff)...
Bought and service my skyline through these dudes! They know their s#$t about imports and specialise in skylines - any model!
Figured this is along the same train of thought as before. Soon as i get my car passed rego i'll need to get an engine immobiliser and possibly alarm system fitted. I don't want anything to elaborate or expensive, it's mainly just to satisfy the insurer.
What systems (and prices) are recommended for the car, and where is a good place to have these items installed? I don't want some 16yo from JBHIFi stuffing around with my car if you get my drift.... :( thanks in advance
Just had my R34 serviced for the big run back to Cairns. Had it serviced by Joe Fister at the Mobil Servo at Garran. I have nothing but praise for the guy. Only required a basic service this time round but he is a Skyline fanatic. Many thanks to Jeremy for the recommendation. Motul 4100 Turbo light in the engine, Redline in the gearbox and Motul 300 in the diff. All good I say.
Cheers
Muz
Need some battery / electrical advice people......
I had a new Optima battery put into the Skyline when I bought it last October. All over summer I had no problems. I went away quite a few times in Autumn, so car wasn't started each time for 3 - 4 -, sometimes 5 days. Each time I tried to start it I thought "Oh s..., this battery is bloody flat". Luckily it whirred back into life slowly both times. After long weekend I was only away for two days and same thing....Last Friday I drove car to work and back again (about 50kms round trip), didn't drive the car Saturday and then yesterday lunchtime I had the slow whirring / almost nothing start again....
I'm thinking either battery or alternator. Thoughts???
Last week I disconnected the amp completely in case it was causing any problems, but there has been no change.
Should I take the car out to Battery Factory and ask em to check it out or
should I book it into a auto electrician? If so are there any recommendations for a auto electric shop either in Fyshwick or Belconnen that knows Skylines? Or should I just take it to Ed or Tez or Garran?
Thanks in advance gurus :):)
Thanks in advance gurus :D  :D
take it back to where you got the battery, they usually have a fairly long warranty these days, they should be able to look at it for free and if the battery is faulty it falls under warranty, but if they tell you its the alternator, take it to the worshop/auto sparkie of your choice, hopefully for you its the battery as new alternators are $1200+ retail
thanks heaps - will do - sheesh, better not be  new alternator, thought it was going to be expensive.
Well its all good----It was a faulty battery. Took the car out to Battery Factory last week. They replaced the Optima with another newbie and kept the Optima for testing. They tested it - charged - tested - drained - etc etc and turns out it was faulty. I am going out there tomorrow to get a brand newbie replacement.
Have nothing but praise for these guys - they are really helpful and loved the car!!!!
Recommended for sure - Battery Factory - near Forty Winks in Fyshwick
Sooo pleased it wasn't the alternator
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
