I should probably interject here, as I've set Charlie up with the routine she is currently doing, but her logs don't fully explain how it works and...as she has just begun the routine...weights and sets do look a bit over the place. I'll use my current bench press as an example. Warmup is 82.5kg x 10 for 2 sets - to be done at a weight you could easily push out 15-20 reps of. Working sets are 92.5kg x 10 for 2 sets - to be done at a weight you can just push out 10 reps of. Max sets are 102.5kg x 4-5 for 2 sets - these are the stepping up sets, where once you reach a predetermined number of reps (for me ~7-8), you step the weight up. So it is not that different to progressive overload, just done on a higher rep range than 5x5.
what exactly are you trying to achieve by doing this? or atleast what do you think you are achiveing? muscle strength or muscle size?
  • Replies 170
Posted Images
I'm not trying to achieve anything, I've already achieved what I set out to do.
of you? no thanks ;)
lol
I will as soon as these mozzie bites disappear off my chest so I don't look like I have rabies or some shit.
dw i got mozzie bites on my arms............ oh wait, they're just my biceps :(
Edited by suwidji
Looking good JEPPE! way to de-gay this thread a bit
I think we need a 'glutes' shot... for science...
I agree...... for science!
+1
Well thanks for the enthusiasm, but they're not ready yet :P
Don't listen to them, I'm not sure you realise this...... but they are just trying to perve on you and get you to post pics of yourself!!!!!! No seriously they are :yes:
Dont fall for it :no:
Send the photos to me and I'll give you an honest, completely objective but most importantly sexually unbiased opinion of how you are going.....
:P
Edited by SRS13
lol wow, and those were the least provocative ones I could take without covering all the relevant parts. I suspected some sort of amusing reaction but I think it's about time we got back on topic, otherwise the ladies won't bother posting again ;)
Guest
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
