I've run spacers on my street and track cars for the last 4 years with no issues.
It will unlikely void your insurance unless it was a contributing factor to the accident ... ie if your wheel cheers off the studs doubt you will be covered but if you get ran up the back of I highly doubt it will
Ooops just realised i wrote warranty, i meant insurance.. sorry it's Saturday lol.
Yeah good point, i just know that in my experience insurance companies will find any excuse NOT to pay you.
buying up parts at the moment to get the V running nicely.
I went for a twistys run with my friend in his new FT86 (both auto)
In the tight stuff he ran away but then as soon as there is anything resembling power required im right back in it.
The FT86 is deifnitely a nice car, but makes the V look like a whale when they are parked side by side
I test drove one before I started tweaking the V...
Couldn't live with that horrible boxer engine! (I owned an AE111 Levin coupe before the V... so I'm not against small rev-happy 4 cylinders).
And I really disliked the fake induction noise set up... My first VQ powered car was stock with a pod filter, and it was so loud I got pulled over and threatened with a defect for my 'loud exhaust' (exhaust was stock)...
in regards to the induction noise you can definitely get them turned off now, but i can see your point. I think you get a lot of kit for the money in terms of new car, but tbh if it were me i would buy a 135i BMW for the same cash (he has a fully optioned GTS)
I was actually about to order an 86 on salary sacrifice but decided to buy a V35 instead privately
But I cant see myself Locked into a car for 4 years, Plus the depreciation so if your get stuck and need to sell it your are way behind on cash
Plates I got like 5 years ago as a joke as It was on my beater drift CA 180sx with unpainted bodykit... Had them so long now cant get rid of them. Even though the red doesn't suit they are beaten up, scrap marks from Oran park (RIP) I'm somewhat emotionally attached to them as gay as it is :P
Its not that I have lots of time, just a hour here or there and doing lots of little jobs, They will dry up soon though as Ive run out of most of those. Exterior is pretty much done besides getting a skirt resprayed (as someone took the protective sticker off and a lot of paint with it )
Something I did yesterday
I was going to order new door grips as mine were all scratched up. Thought I might have a go at restoring them as worse case I'll but a new pair anyway.
Before
Sanded with 400, 2 coats plastic prime, 3 coats random silver (close to exterior colour) had in the garage, 2 coats clear.
Its different to the other silver a fair bit, but will do for now till I get a bunch of stuff from the US
Pleased to announce that i have finally ordered my brand new CD009 gearbox and everything else needed like chromoly pivot ball, ss clutch lines and nismo bushings. Along with the new gearbox i have also got a Southbend (Exedy) Clutch & Steel Flywheel, Amsoil 75w90 gl4 gearbox oil and Amsoil 75w90 gl5 diff oil.
AND i have ordered a RJM clutch bracket, this is meant to make the notorious "knotchy" or "rough" 1st to 2nd gear change much much smoother. I have also semi-booked a date to get it all fitted through a local shop, i am keen as beans!
I got my tein s-techs installed today....now waiting for them to settle and then do the alignment////
anyone know how long I should wait for them to settle?
tomorrow I'm gonna install the z-tube/pop charger combo myself....wish me luck :whistling:
Locky i am home now, i finally see your car! Looks clean mate, i too need to clean up the door handle silver thingy.
I like the wheels, the front licence plate looks tiny compared to the normal ones hey.
I have just replaced my bose door speaker, got a 2nd hand one off a guy named Josh that bought a v35 wreck. Works like new, finally my right ear can join my left ear in enjoying house music again!
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
