hey guys what would the title be for the above product? looks good i may want to change the silver plastic look...
If you were referring to mine, it was from mimoUSA. They do dash kits for the G35, but were able to convert that to the RHD v35 and take into account things like not having the analogue clock in the middle. They use real carbon fibre.
I bought mine through ebay.
The material itself seems to be pretty high quality. The finish is good, as is the adhesive. The fit was pretty spot on for each part of the dash. The only thing that concerns me were the cuts - some were rough - I had to take a stanley knife to a couple of edges.
I think this is because I chose real carbon fibre as opposed to a different finish - it may be thicker than normal? I'm not sure.
All I can say is the more I drive the car, the more I like the look of the kit!
That looks fkn hot
They look like front 19 9.5 +12 and rear 19 10.5 +12 ????
I was gonna but the exact same setup ... Need to sell my oem rays first
Yes, that is the spec
Is your car lowered on springs or coilovers?
Cheap coilovers, but they do the job. Rears are maxxed, fronts could go much lower.
is it just me or is it half up on the gutter so looks lower :lol:
It is 1/2 on the gutter, but height is still the same. Some more crap phone photo's.
Original height was too low so raised by about 10mm, this was how it sat before I raised it:
Shredding paint!
It is relatively easy to drop the rear, 275 35 19's only scrub on heavy bumps with someone in the back seat. The front is lower by default due to the stock staggered fitment. I cheated by running a square setup with 245 40 19's on the front. Same rolling diam as rear so give you more clearance and close the tyre/arch gap. I've had stretched tyres before and do like the look, you have to go real low to pull it off. 235's on the front would be an easier fit. Oh and fat is the new stretch, haven't you heard :woot:
Edited by Superpoo
275 35 rear, 245 40 front
I was told by a tyre shop that if u ran less profile on rears, the car would not sit balanced, the rear would be lower than the fronts, is this true?
the guy recommended me get 40's all round or 35 on front and 40 on rear.
Stock runs staggered. The profile is the same, widths differ, so overall diameter is different front to rear (rear is bigger). The danger of running square (what I have now) is tripping the stability control, the computer thinks the rear is spinning faster than the front and kicks in. Hasn't happened yet and the opinion on the internet is mixed so I will see how I go.
The only benefit is you gain some ride height and loose some guard clearance.
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
