reviving an old topic :action-smiley-069:
decided to give the plastidip thingy a go today, did my front grille and rear diffuser. The grille turned out okay..got a few small run spots if you look close but from far it looks good imo. I did 4 layers on each with 1 can which was almost empty when i finished. The diffuser didn't turn out as good as i wanted it to be but being first time i think it was okay...will learn from my mistakes i guess. Anyway pictures say more than words, here's a few pics i took along the process (only took a few as i was racing against daylight to get it finished.
Grille (was a bitch to take off lol..)
after
Diffuser
i was bit paranoid about overspray...hence the ridiculous amount of paper lol
after....i ran out of sunlight :down:
dd94bc92-8da8-4ac4-98e1-c0a8075156dd-1.j
took me about 2 hours ish, that was including washing the car and prep work :happy:
after
Diffuser
Looks good.. :) Why do you think diffuser didnt come out good? I was thinking of doing the same so any tips would be handy.
Cheers
When you peel off the masking around the edges the dip tends to stick and wants to come off with it. I was being pretty careful but still left a few tiny spots on the edges. After some reading I found out you can either spray the coats on fairly quickly, don't allow it to dry and peel off the masking while its still wet, that way you get a smooth clean edge. Or, you can use a razor blade and cut alone the edges where it bonds to the tape and take it off that way, hope this helps. =)
Thanks mate, I ll see how I go.. :)
Chucked all that stuff on and removed the bottom resonater from the air box too.
Surprised at how much induction noise for a stock setup now :)
How do you take out the bottom resonater from the air box? Does it just come out or did you have to cut it off?
By the way are you referring to the part in this photo or is it at the bottom of the air box?
Thanks Locky.
Cleaned the throttle bodies of my 370GT this weekend, as I was experiencing idling issues (sometimes the car would stall...)
Bit of a pain to do if you can't remove your strutbar, but it makes a world of difference.
Mine was covered in black grime, and now its nice and golden..
mods i have done from then to now
Coilovers
19x11+15 varrstoen 1.1.2 (please don't hate on wheel caps came with the wheels :P)
JDM Double din stereo kit
Custom Y Pipe back exhuast system
Roof Spoiler
Hey Sarl,
Where did you get the varrstoen from? and what coilovers do you have? Did you have to roll your guards/ fenders with the setup?
Thanks
Hey Sarl,
Thanks
i traded my old wheels for them on gumtree, but ebay has a varrstoen seller which seems legit.
had some basic coilover i found on this page but might upgraded later on to bc's
all i needed to do was rolled the guards and had to shave a bit or my rear bumper lip inside and also camber
hope that helped rawzz
Bought a Greddy emanage ultimate with boost sensor, loom and laptop with software for the VQ25DET swap in my sedan.
Also bought a rare-ish woodgrain MOMO optioned steering wheel.
Did UpRev tune yesterday. Not too bad I think :)
Nice, workshop and details?
Pity the run rate is different on the runs. The curves aren't really comparable. How does it drive?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
