reviving an old topic :action-smiley-069:
decided to give the plastidip thingy a go today, did my front grille and rear diffuser. The grille turned out okay..got a few small run spots if you look close but from far it looks good imo. I did 4 layers on each with 1 can which was almost empty when i finished. The diffuser didn't turn out as good as i wanted it to be but being first time i think it was okay...will learn from my mistakes i guess. Anyway pictures say more than words, here's a few pics i took along the process (only took a few as i was racing against daylight to get it finished.
Grille (was a bitch to take off lol..)
after
Diffuser
i was bit paranoid about overspray...hence the ridiculous amount of paper lol
after....i ran out of sunlight :down:
dd94bc92-8da8-4ac4-98e1-c0a8075156dd-1.j
took me about 2 hours ish, that was including washing the car and prep work :happy:
after
Diffuser
Looks good.. :) Why do you think diffuser didnt come out good? I was thinking of doing the same so any tips would be handy.
Cheers
When you peel off the masking around the edges the dip tends to stick and wants to come off with it. I was being pretty careful but still left a few tiny spots on the edges. After some reading I found out you can either spray the coats on fairly quickly, don't allow it to dry and peel off the masking while its still wet, that way you get a smooth clean edge. Or, you can use a razor blade and cut alone the edges where it bonds to the tape and take it off that way, hope this helps. =)
Thanks mate, I ll see how I go.. :)
Chucked all that stuff on and removed the bottom resonater from the air box too.
Surprised at how much induction noise for a stock setup now :)
How do you take out the bottom resonater from the air box? Does it just come out or did you have to cut it off?
By the way are you referring to the part in this photo or is it at the bottom of the air box?
Thanks Locky.
Cleaned the throttle bodies of my 370GT this weekend, as I was experiencing idling issues (sometimes the car would stall...)
Bit of a pain to do if you can't remove your strutbar, but it makes a world of difference.
Mine was covered in black grime, and now its nice and golden..
mods i have done from then to now
Coilovers
19x11+15 varrstoen 1.1.2 (please don't hate on wheel caps came with the wheels :P)
JDM Double din stereo kit
Custom Y Pipe back exhuast system
Roof Spoiler
Hey Sarl,
Where did you get the varrstoen from? and what coilovers do you have? Did you have to roll your guards/ fenders with the setup?
Thanks
Hey Sarl,
Thanks
i traded my old wheels for them on gumtree, but ebay has a varrstoen seller which seems legit.
had some basic coilover i found on this page but might upgraded later on to bc's
all i needed to do was rolled the guards and had to shave a bit or my rear bumper lip inside and also camber
hope that helped rawzz
Bought a Greddy emanage ultimate with boost sensor, loom and laptop with software for the VQ25DET swap in my sedan.
Also bought a rare-ish woodgrain MOMO optioned steering wheel.
Did UpRev tune yesterday. Not too bad I think :)
Nice, workshop and details?
Pity the run rate is different on the runs. The curves aren't really comparable. How does it drive?
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
