reviving an old topic :action-smiley-069:
decided to give the plastidip thingy a go today, did my front grille and rear diffuser. The grille turned out okay..got a few small run spots if you look close but from far it looks good imo. I did 4 layers on each with 1 can which was almost empty when i finished. The diffuser didn't turn out as good as i wanted it to be but being first time i think it was okay...will learn from my mistakes i guess. Anyway pictures say more than words, here's a few pics i took along the process (only took a few as i was racing against daylight to get it finished.
Grille (was a bitch to take off lol..)
after
Diffuser
i was bit paranoid about overspray...hence the ridiculous amount of paper lol
after....i ran out of sunlight :down:
dd94bc92-8da8-4ac4-98e1-c0a8075156dd-1.j
took me about 2 hours ish, that was including washing the car and prep work :happy:
after
Diffuser
Looks good.. :) Why do you think diffuser didnt come out good? I was thinking of doing the same so any tips would be handy.
Cheers
When you peel off the masking around the edges the dip tends to stick and wants to come off with it. I was being pretty careful but still left a few tiny spots on the edges. After some reading I found out you can either spray the coats on fairly quickly, don't allow it to dry and peel off the masking while its still wet, that way you get a smooth clean edge. Or, you can use a razor blade and cut alone the edges where it bonds to the tape and take it off that way, hope this helps. =)
Thanks mate, I ll see how I go.. :)
Chucked all that stuff on and removed the bottom resonater from the air box too.
Surprised at how much induction noise for a stock setup now :)
How do you take out the bottom resonater from the air box? Does it just come out or did you have to cut it off?
By the way are you referring to the part in this photo or is it at the bottom of the air box?
Thanks Locky.
Cleaned the throttle bodies of my 370GT this weekend, as I was experiencing idling issues (sometimes the car would stall...)
Bit of a pain to do if you can't remove your strutbar, but it makes a world of difference.
Mine was covered in black grime, and now its nice and golden..
mods i have done from then to now
Coilovers
19x11+15 varrstoen 1.1.2 (please don't hate on wheel caps came with the wheels :P)
JDM Double din stereo kit
Custom Y Pipe back exhuast system
Roof Spoiler
Hey Sarl,
Where did you get the varrstoen from? and what coilovers do you have? Did you have to roll your guards/ fenders with the setup?
Thanks
Hey Sarl,
Thanks
i traded my old wheels for them on gumtree, but ebay has a varrstoen seller which seems legit.
had some basic coilover i found on this page but might upgraded later on to bc's
all i needed to do was rolled the guards and had to shave a bit or my rear bumper lip inside and also camber
hope that helped rawzz
Bought a Greddy emanage ultimate with boost sensor, loom and laptop with software for the VQ25DET swap in my sedan.
Also bought a rare-ish woodgrain MOMO optioned steering wheel.
Did UpRev tune yesterday. Not too bad I think :)
Nice, workshop and details?
Pity the run rate is different on the runs. The curves aren't really comparable. How does it drive?
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
