Do the Hustle!!!
Turns out my oil temp works just fine as I did hook it to the sensor but the car didn't get warm enough to register.
1000 @ 100km / hr on the highway. Now to get my water sensor adapter on... :)
Do the Hustle!!!
Its sad that you know what the Hustle is mate.....Oh wait....So do I.
Drove her to work. New rubber is fantastic.
On a less positive side: One of my wheels has chipped the paint off it, anyone know roughly what price/where i can get slight gutter rash fixed, and fresh paint on all four?
Finally got around to fitting a factory ac thermo fan. took a while to get the intercooler to line up right and its mounted a little lower and its tight but its better than no thermo fan :P
It has a bit of a miss after sitting for almost three months. Hoping its just plugs or something simple.
There used to be a whole thread on this subject .... Not so long ago. ... With some good tips.
This Thread ---->> http://www.skylinesaustralia.com/forums/topic/383892-wheel-repairrepaint-in-canberra/
Wicked Wheels, Rallimax, Craved Coatings etc...
Finally purchase a new front bumper. Any places that do good installation jobs? No idea if the previous owners screwed with the front of my car or not to put my current bumper on.
bought $150 worth of meguairs products, as i finished all of mine of prepping a car for a wedding on the weekend. The car (2005 C320 Merc) cleaned up better than i would have thought, was told that it looked like it had just rolled out from factory!
So overall very happy. Unfortunately won't get a chance to detail this weekend as im booked out the whole time.
GTR needs some love atm....
Also got some new vacuum lines and a few other bits and peices to tidy the engine bay up.
Oh and the stickers arrived for my wheels last night. Will test fit tonight.
Bryce just finished installing stockie suspension in Rosie - I feel like I'm driving on clouds haha. Absolute Legend. May have to fit Stockie wheels as the front is a bit low.
Cheers Bryce, ya legend.
Edited by RosieR34
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
