Just kept looking at the empty space under the hood :/
no good mate. Maybe a Valentines day pressie ??
so I'll just rub it in a bit more. Drove my GTR all morning !
Such a hard-on I'm sitting in the ER room waiting for a relaxant :P
started cleaning up the car interior to something a little less disgusting. fabric clean in early stages befor i rip it all out for a retrim.
btw who has removed the rear seats/ ive bought a new parcel shelf so i can get rid of the existing damaged ones and ugly 6x9s....
Fark you :)
But as I am retired I can drive it all day while the kids are at school , well , when I get it back :(
Ever driven down the Lakesway from Bulladhela to Forster.
You do not have to go over the limit just to enjoy the drive, 50 Klms of different roadway , 100 both ways best start you can get before breakfast, do the full run at at least once a week :)
Just have to dodge the potholes :)
Nate the 32 has 2 clips on the base of the rear seat. Push back and lift up. It's usually stuck in there good so it needs a bit of force. Then it just lifts out. The top section will have 2 bolts that you will see when you remove the bottom half. The parcel shelf has 4 or so white clips that you push up from the boot.
I did i. Couple of weeks ago lol
  • Like 1
OEM shifter in this morning and my C's short shifter is out.
So if your after one in top nick then hit me up. Just put it up in the general FS section.
LH drive shaft is being replaced ATM
RH drive shaft was done about a month ago and the left was fine then
When the new exhaust was put in on Friday I noticed the boot had split on the left one.
The work required to change the boot is about the same as replacing the drive shaft, so rather put a reco back in.
Although it's only just split and could get away with just replacing the boot I'd rather change the whole shaft/joint out.
Edited by Sinista32
Hmm everyone doing something big while I do small stuff that I probably shouldn't even bother mentioning...but I will do anyway :P
I replaced the parklights with white LED ones to go with the xenon lights
The harder it gets the more fun, sometimes it becomes personal haha
I am trying to find out what can I use to clean my headlights, they have that scuffy dirty look, any product advice?
Edited by R34_luvr
TOOTHPASTE!!! Haha Nah, I dunno. When I took my car for a service at Trojan they cleaned it up and hasn't had that yellow gunk for around 3-4 months now.
Toothpaste does actually work.
Are your headlights glass or plastic?
If plastic, there isn't anything you can really do. If glass you can get a kit to restore them. Meguairs make one that you can get at any supercheap.
This kit will work on plastic as well. But the yellow is caused by the sun damaging the plastic. So they will look good for a few months and then will require treatment again.
Toothpaste, Car Polish / Cut n Polish, Avacado, basically any mild abrasive.
You will need to repeat from time to time as the UV coating will be removed but you may be able to seal the surface after you treat it.
Various products on the market also. -->> http://www.meguiarsdirect.com/product/plastx-clear-plastic-cleaner-and-polish
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
