I start a new job on the 24th, and car is set up for nulon nats drags on the 26th. Wakefield eventually though!
Today I got road tyres fitted, installed a EBC and set it up to run 14psi and 19psi as the scramble boost setting.
Also installed a passenger seat.
  • Like 2
good job on the steering previous page
today I put in new door locks, boot lock and will get the new ign barrel put in soon at Johns
decided to cut and use the Nismo key on my gtr32, so it deserved complete set of new locks
  • Like 1
I opened up my bonnet and heard what sounds like a exhaust leak..close the bonnet and drove to the shops lol
That makes two of us haha.. Did pretty much the same thing!
That is so cool!!
I replaced my exhaust manifold gasket because of a leak, got a new turbo gasket thanks to Shiv. Also discovered a manifold stud snapped in the head thanks to previous owners.. Tapped out and all fixed. Just to put it all back together tomorrow! :)
  • Like 2
1.5 way diff installed thank you Canberra Import Spares! Was doing figure 8s out at Harrison playing fields car park breaking in the diff when the cops showed up on reports of a skyline doing donuts.
I had a chat to them for a few minutes and they had a laugh when picked up on what I was doing - no skid marks and tyres in good condition. Told me not to have too much fun and left me to continue. Nice blokes!
  • Like 4
Dropped the rear end to swap back to an s13 subframe. Have to get cv boots replaced and the diff looked at, one of the stubs doesn't lock in.
And of course one of the driveshafts is stuck in the hub so the whole lot has to go to Craig Hall to be fixed.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
