Hi all
new to the forums and owning a skyline(first one)
i had an issue the second day of ownership :angry: was very unhappy jan,
but it turned out to be that the previous owner had decided to use carby fuel hose from the pump to the top of the fuel tank instead of using proper efi hose
and it burst in the tank, had that fixed and now when i am at WOT i feel a bit of surging (the car is manual(converted)) and is running 12-13 psi of boost (bought like this)
std intercooler car came with a exhaust haven't had time to measure or check brand
i am going to try turning down boost before exhaust wheel shits its self but wondering if any one had any other ideas as to what could be causing this
regards
aphex
https://www.sau.com.au/forums/topic/415612-r33-gtst-surging-under-heavy-boost/
describe your surging? I think you're mistaking it with R&R.. the car just hits a brick wall and comes back to life and hits another brick wall...
Too much boost buddy for the stock ECU, it just falls into the wrong cells and bam massive timing pull. I even get that at 0.8bar on cold nights, I just run 0.7bar all day
Hi all
regards
aphex
are you sure it is a stock turbo? could it be something else eg a 2876?
stock turbo would be snapped in half before it could reach its surging limit. might've been afm dirty or miss firing.
The type of surging ive heard is not mistakable, has a distinct sound, take the intake pipe off to see if the compressor wheel has left a grove in the cover, my brothers skyline turned out to have a gt2876, it has a line carve out of the compressor cover.
Maybe inspect the fuel tank for debris and change fuel filter a few times.
cheers all for the reply's
i have dialled it back to 10 psi and it has improved but is still there.
When hot the vehicle hesitates/surges i have tried 98 and 100 ron fuel
i thought it might be a battery problem so i replaced to no avail
will pick some contact cleaner for the maf and a fuel filter as well as some sparks tonight
mods: sh*$y drift boost controller, stock BOV, stock intercooler, pod filter
PS: the vehicle smells very rich after snapping the throttle open
regards
aphex
cheers all,
i have cleaned maf sensor with ecc it improved the issue a little but it is still there.
any 1 have any ideas on how to free the stuck rubber hose on the fuel filter (tried bottle nose pliers but don't want to munch the fuel hose) it looks as if it has been on there a while
i also have injector cleaner but dont want to use it till i have a fresh fuel filter in there.
have found the issue is evident in low gears under accel (any) once in 4th-5th at 80km/h-100km/h it will pull fine
ps. what does RnR stand for?
regards
andreas
Edited by aphexcloud
i wasn't looking for an explanation.
i was wondering what does the Acronym mean... so i could do some research on it
http://lmgtfy.com/?q...esaustralia.com
5th hit, and that's using the less common RnR version rather than R&R.
Edited by GTSBoy
cheers all,
Cut it off and replace it.
Yeah, my point was given that you had been told it was R&R, you could have googled it for yourself in less time than it took to ask. I'm just trying to discourage the spoonfeeding mentality on forums.
why isnt that what we are here for? to offer help, support and advice to people that dont know very much.
god knows what you did before google my friend.
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
