Hi all!
need some major help with my skyline, renctly wound the boost up to 1.3 bar for a track day,
long story short blew exuast manifold gasket, put a new one in took it for a drive and the car hesitates to boost, at about .3 bar it feels like it hits a wall. looses all power until you take foot off the throttle and it will come back to life.
Ive changed;
Spark plugs and gaped to .8
new coil packs
AFM
checked;
sensors
boost leaks- none that i could find with carby cleaner
Also tried re setting the ECU
Can any body throw some suggestions my way??
https://www.sau.com.au/forums/topic/415844-rb25det-fuel-cut/
well the guy that advice me to do that organises all the drift meets here, forgot to mentioned i thort i might have blown the turbo so i took it out and checked it but it seems to be fine and ive also put another standard turbo on just to eliminate that possability,
ive wound it back down to standard psi, now its running rich on idle and when it starts boosting feel like you hit a wall
ive searched RnR but not convinced that its that..
anither thing is when it starts boosting (before it hits the wall) it soulds like the psi coming out some where from the left hand side, sounds odd and its hard to explaind but ive looked at thres for the last couple of months tryi to diagnose this problem
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
