Hey guys i have a sweet RS*R 3.5" catback which is great but it is way too quiet (for me) it seems a waste to get a whole new catback and i dont want to hack up the current one.
The culprit is the rear muffler flows great but too quiet, basically i want to get a this(link below) to replace the rear muffler. Rather than cut off the old one and weld this on, i want to get to get this one made up to mate with the flange after the diff. So if need be i can bolt the quiet one back on.
Can anyone recommend a place in canberra who can do 3.5" exhaust work.
Cheers
Patrick
http://www.ebay.com.au/itm/Apexi-N1-Universal-Muffler-3-5inch-Nissan-Toyota-Mitsubishi-Subaru-Mazda-Hyundai-/271051187182?pt=AU_Car_Parts_Accessories&hash=item3f1be8e3ee
That's pretty good in comparison to the pre fab jap exhausts. Stainless might be a touch more though yeh?
You thinking of going custom exhaust kasko?
I think my exhaust is currently to quiet for pretty much straight through so something must be a restriction. Already 3.5 inch cat back so I don't know might pull it off when I get back from the coast and check what the dump and everything is
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
