List price through Nissan is $1300 ex Japan ...
Cheap as :P
I always thought the Hitachi CAS was easier to rebuild but apparently not? probably should of had a go at my spare broken CAS today but forgot all about it.
So I pulled one of my spare CAS apart yesturday and all went pretty good, I had to drill the pin that holds the engagement drive out and bent the pickup disc a bit. Not sure if the new sensor comes with a new disc? I was thinking about just using a roll pin (Cutting down to size) in the hole for the engagement drive
Is there any parts list at all for these? Bearings are easy enough to replace but the rest of the stuff not so much
So bearing is easy enough without doing any damage? My bearing is a little notchy.
you have to pull the engagement drive off the shaft to get one of the bearings off. To do this you need to get the disc out of the sensor. I think you can unscrew half the sensor and just move it away (this is how I did it) but not 100% sure that this doesnt damage the sensor.
Edited by 89CAL
  • 7 months later...
Does anyone know if the Hitachi CAS is a direct swap to the Mitsubishi CAS?
I bought a second hand Mitsubishi CAS but the wiring plug is different between the two CAS units. If the wiring pin out is the same i'm thinking about sourcing a plug to rewire the loom to try the Mitsubishi CAS. Plus side would be that you can still buy the Mitsubishi CAS brand new but not the Hitachi.
No they are not. Wiring is least of your problems - wiring needs to be reversed but the drive on the end of the camshaft is different.
I'll have to get a Photo of the 2 different CAS i have, both are for the r33 RB25 not the NEO. both have the same shaft that goes into the camshaft.
Just looking at the CAS one has the Mitsubishi logo visible the other does no just a solid metal case.
Did a quick search and found one that i have on my car (1995 R33 S1.5 RB25DET) 104_0638-1.jpg
This is the Mitsubishi CAS that has a different plug to the one above IMG_0405.jpg
I ended up buying a new one at the time because I needed good signals for and aftermarket brain . People tell me that these CAS units go off over time and most original ones won't be at their best . Lots of heat cycles and bearings wear over time .
New can be expensive but probably the simplest and best result .
A .
Those are both Mitsubishi CAS and the plug should fit both. I have had both on my car
This is a Hitachi CAS:
Genuine-Nissan-Cam-Crank-Angle-Sensor-23
If the 2 CAS' you have pictured are in any way different, one will be an RB25 CAS and one would possibly be a CA18 CAS
  • Like 1
Now i'm confused, i bought a R33 RB25DET CAS of Ebay ( and it is the Mitsubishi logo one but is a diffrent plug.. did CA18s come out with the Mitsubishi ones? im thinking the one from ebay might not be a true rb25 cas but did come with the engine bracket that the cas bolts onto under the timing belt cover which is defiantly for rb25.
Ill get some photos tomorrow if someone could help and confirm if i have the same plug or a different CAS plug.
Dont have the tools to open it, has tamper safe screws.
1377300246139.jpg my current one is on the left.
That's a shame as the r34 cas (hitachi)has two Philips heads screws
Edited by StevenCJR31
Thanks for confirming, now to see if i can get my money back via PayPal as it was advertised as a RB25 turbo CAS.
Is Kudos Motorsport the cheapest place to buy a CAS brand new? currently $660 http://www.kudosmotorsports.com/catalog/nissan-cam-crank-angle-sensor-cas-genuine-nissan-skyline-r32-gtr-gtst-gts4-gts25-r33-gtr-gts25t-gts4-p-1176.html
The one on the left is an rb25 one. Not sure what the one on the right is off. Z32 or CA18 I guess?
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
