Hey all,
I finally decided I would create a thread for my 1989 R32 GTR. Now a bit of a warning, there are a few photos here so i will have to split this over a few posts. The rest of the photos are on my photobucket (assuming my internet fixes itself!)
Before the GTR i had had a R32 gts-t which was my 1st introduction to imports. I loved it, then made the silly mistake of putting a rb25 into it.
Whilst it went really well, it was unreliable and a pain to drive, so long story short i swapped it for an s13 with rb20, coilovers and a few other bits and pieces.
This was my daily for a little while until i heard of a cheap gtr for sale. after lusting after one for so long i was so happy to have found one for cheap and didnt even have to travel to get it. I went and saw the bloke selling it to have a look. I was blown away with how good it looked even with tacky (in my opinion) chrome bits and pieces.
So i had to ask the question "why is it so cheap?". The answer was simple, it had what the owner thought was a rod knock. When he started it there was a pretty bad noise, but came from the head, not the bottom end.
So knowing there was something that wasnt fun going on, i thanked the bloke, and told him i would keep in touch. After looking online at motors and stuff i decided that i could yank the motor and replace it with another standard one so i called the bloke back and said id take it.
After getting the car home i decided i would investigate the noise before i purchased another motor.
Anyway to cut a long story short and speed this up a little the oil was putrid and really thick so i changed it a few times to get all the old stuff out. I noticed after the first oil change the noise was quieter and after the 2nd one was gone completely. Win! So i did some investiagtion and it was only a slightly sticky lifter from having putrid oil. Anyway first drive on a permit, bam! rear turbo gooooone :(. So whilst being pretty devo and realising it was going to be a massive sh!t fight to change the turbo i reefed them off and bought a dirty single manifold.
I then got a 2nd hand turbo off a mate which is aparently a trust t67r. So my christmas 2011 was spent removing old turbos and installing the new one. Also got a 100mm tube and fin cooler whilst i had the front end off it.
After installing all this stuff (tomei reg and a few other little bits and pieces went in at the same time) i had the hard decision, do i make/find a greddy style intake that let me use the standard mafs and run a power FC? Nah. Did some research and came across the haltech range of products. Just a quick google showed me that it was way more than i currently needed, but i had plans to make a bit more power and didnt want to shell out for bigger afms later. Not to mention the cool gadgets the haltech can have added to it. So i forked out the 1800 they wanted, Merry christmas to me!
Installed that at the same time as some 720cc injectors and a hks fuel rail. So as i was waiting for my tuner to have some time to tune it i decided i would get the front and rear bars resprayed by a mate who is a painter. one thing led to another and i was striping the car for a respray. Fark. Anyway i pulled it apart and prepped it all myself. Two days before it was due to roll into the booth it decided not to start. Great. no spark.
I thought the igniter had crapped itself. Borrowed another one and no dice still. Scratching my head as to why there was only a weak spark i changed coilpacks to spares that i knew worked. Still only weak spark. I decided that i had just got 2 bad igniters and re-wired the coilpack soom to remove the igniter and use rb25 s2 coils just like i had on my old r32. After all this trouble still nothing. so i had a long hard think about it and decided to put the jerrycan and lighter away and check everthing. Ecu unplugged and plugged back in, nothing. changed to std ecu, nothing. haltech back in still nothing. unplugged the two green relays next to the ecu and switched them. Coughed an spluttered into life!! Dunno why they werent working but cleaned all the contacts and it started again. Pretty random problem to have but whatever it was fixed!
Whilst this was going on my painter had switched shops and couldnt use the booth at his new shop for a while. FUUUUUUUUUUUUUUU. So i just started buying bits and pieces for the fuel system and suspension. Finally the time came to get it in and done.
It got primered then my "mate" that i was paying to do it didnt want to spend anytime on it even though i had done all the prepwork ready for basecoat and paid him. lesson learnt. Some 2 months later it got painted. Finally!!! Test fitted my wheels just before the basecoat went on to ensure i had rolled the guards enough.
Was super happy that it was finally done and ready to be put back together.
https://www.sau.com.au/forums/topic/416149-k_ds-1989-r32-gtr-build/
Got it mostly back together and sent it to get tuned.
The next day i got a voicemail from the tuner asking if i could please call him back ( i wasnt expecting it back for another few days :/). Fearing it had thrown a rod or bottom ended i called him back fearing the worst. Luckily it was just my stupid low slung exhaust + rubbish suspension meaning that when they strapped it the exhaust would hit the roller. Ooops. took it home on friday night and put coilovers and cams in at the same time over the weekend. Took it back on the monday and got told off for pulling the CAS off and putting it back on slightly out :P. Got it tuned on pump fuel (injectors werent big enough for e85 DOH!!). Made more than i expected, 313rwkw at gatespring pressure (15psi). I was stoked and told him not to use the controller to try preserve the bottom end. Driving it home for the 1st time in a year was the best feeling, but being double demerits decided to cruise safely home license intact. Anyway this is how it sits now, still with its 4x4 ride height from the dyno. Currently waiting for my ID2000s to turn up, and some more cash dollar to start building a forged bottom end.
Thanks for reading, sorry its so long, i forgot the dramas i had with it! Please let me know what you think :)
Thanks goes out to Jason @ Japspec Garage, John @ Trojan Motorsport, Rob & Vic @ Aussie Automotive, and numerous other people that i have forgotten :)
As it stands i have done all the work on this car aside from the tune, some of the respray and making the dump pipe. Spec list is currently as follows:
12/89 R32 GTR
Custom HOK galaxy grey respray.
N1 bonnet and boot lips.
Koya CR tek 18x9.5 +22
Advan neova 265/40/18
Standard (as far as i am aware) rb26
Tomei type B poncams
Ssr cam gears
Supposidly trust t67r
Xspower stainless manifold
Tial 38mm Mvr gate
Standard radiator with a thermofan
100mm tube and fin cooler (cant remember brand)
3"mild steel dump
Stainless decat pipe
3.5 / 4" exhaust with apexi cannon
HKS fuel rail
Denso 720cc injectors
Tomei FPR
Speedflow Fittings and Parker pushlock hose
1/2" moroso alloy fuel feed line
Mallory Fuel filter
2x bosch 044 pumps
walbro intank pump
2.5ltr surge tank
Haltech Flex fuel sensor
Haltech platinum pro plugin ECu
Haltech wideband 02 controller
Haltech Input/Output expander
Nismo gear knob
Autometer boost gauge
Shitty drift wheel
Bridgestone NPG coilovers
Whiteline front strutbrace
SRI solid supframe collars
Hicas lock bar
Hardrace adjustable rear camber and traction arms
  • Like 1
Looks really good slightly more gold/copper tinge.
Great looking GTR man.
Thanks mate. Will get someone who knows what they are doing with a camera to take some proper photos as in the sun its nearly a bronze!
Good work, seen in the flesh recently.
Might be worth checking/replacing crank collar and oil pump if the engine is indeed unopend and stock.
Hate to see you having to rebuild the engine.
Your now pushing over 300kws so it will come sooner rather than later if your not careful.
Hate to be a worry wart but it happend to me.
Cheers Richard,
I was going to do that, but im starting to order stuff for a new bottom end now, and dont plan on driving it much till thats done.
Installing the collars requires removing the crank doesnt it?
Love the custom colour, really suits it
Set of N1 headlights in that would look good
Just don't be tempted to turn the boost up on that turbo with stock motor, i leaned my old R out years ago with standard turbos and popped an engine, could just imagine what damage that beast could do ;)
Its hard not to, so i pulled the controller out the other day to resist temptation!
N1 headlights or rods hmmmmmm. I think rods might be a better investment at the moment, although i do agree the n1's look better and you can actually see with them unlike these rubbish projectors.
  • 1 month later...
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
