  • Replies 172
Posted Images
The water piping for an RB's oil heat exchanger enters the from the rear water exit for the block (also the feed for the heater) and exist the exchanger into the water pump inlet post thermostat.
Here's a question, what location should we be getting our oil temperature from?
Should we be getting it from the bottom of the sump or post oil cooler as it enters the engine's main gallery?
You need to know where it is hottest. It is not important that you are providing it to the engine at a good temperature (post cooler). What is important is that you know how hot it actually gets. As such, the sump (or post oil pump sandwich plate) is the best location.
Or both, if you want to know everything!
Hah!
Question. When does oil break down?
Answer. When it is hot.
Second question. How do you know how hot it has gotten, if you haven't measured it when it was hot?
Second answer. You don't.
You shove "cool enough" oil into your engine and pat yourself on the back. But whilst hanging around in the main feed gallery, it gets hot. Maybe it gets hot enough that whilst it's actually in the journals it starts to crap itself. Oh well. So sad.
so the answer is measure it at its hottest?
... still dont know where we are taking the reading from....The sump, the filter housing, before the cooler if your using one????
im not 100% clear on the flow of oil through an RB engine
Hah!
Given your bearing dimensions are fixed the variables affecting the bearing performance are speed, flow rate and viscosity. Viscosity can double in 10 deg increments depending where are you are in the temp/viscosity range (log scale). The industrial scale bearings I'm involved with trip on 'feed' lube temperature, given an increase in temp of 5 deg above the trip point can drop the viscosity to a point where bearings fail (lube film is dependant on viscosity, load and speed). Ideally you want to know the temp at the bearing but in reality you have to settle for going as close to the bearing as possible. Oil is tested regularly and replaced based on the rate of deterioration (in most cases contamination happens first).
Now I'll ask you, how do you measure the maximum temp the oil reaches? At best you can measure the temp in the reservoir/sump or after the pump/before the filter, so using your argument - you still have no idea what the max oil temp is nor if the oil has reached a temp where it will break down. Your best of getting the oil tested to figure that part out.
is there really going to be that much temp difference between the bearing and the filter though?
I mean the split second it gets hot at the bearing surely couldn't do damage that couldn't be read at the sensor/filter and knowing what temp you should ease up on it which seems to be around 120...
It is FAR more conservative and safe to measure the higher temperature rather than the lower temperature. Your industrial bearings are often just that....a bearing. Sure, they may be massive with massive loads on them. Sure, they may be running very fast. But they are seldom embedded within a bloody hot cast iron heat source as well. The lube oil usually flows via a nice hose from the remote pump to the bearing and the performance of the bearing under load is sufficiently well known by the manufacturer and/or commissioning engineer that they can tell the operator to trip it off based on ain inlet temperature because they know how hot it will heat up to. In our engines the bearings' oil feed is in an uncontrolled heater so you don't know how hot it is going in. If you measure it in the sump at 120°C then you know damn well that it had to have been at least that hot in the bearing itself. If you measure it at 105°C after the cooler.......you have no idea what the bearing has been running at. Just a wild guess. Could have been 140°C and breaking down for all you know.
Engineering is about identifying what is important, not just working from other examples.
Where does the standard temp sensor read from?
The heat exchanger where the oil filter mounts.... which is just before it goes into the engine. A couple of people here know what they are talking about.
Edited by bigmikespec
In the interests of maintaining my sanity I concede, but thanks for the tip - I'll be sure to pass it on to my grads :)
I don't see the zing.
With respect to the location of the oem temp sensor.....that one doesn't really matter where it is. There is no oil cooler in the equation (oil-water HX notwithstanding) and so the oil temperature will be about the same whether measured in the sump, after the pump, after the HX or after the filter. That example in no way nullifies my position.
The people who I supervise are not engineering graduates. They have PhDs.
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
