What Holset For Standard Fj20
D-limo
 Share
Hi Looking at a turbo upgrade for my standard late model (lower compression) FJ20. After checking current highflow at prices I've decided Holset is the go.
Firstly can someone explain how the T3 twin scroll exhaust housing fits onto the standard DR30 manifold? Does the standard open mouthed manifold flange just pump ex gasses straight into the split ports of the housing?
And is the standard actuator fine to run by itself or will I gain anything using a quality bleed valve? (GFB)
What versions of the HX30 HX30/40 HX40 series should I be looking at?
There is no point using a twin scroll turbo on a standard manifold as it would be laggy as hell. If ur on a small budget do what Scotty said snd contact hypergear on this forum, he will help u out with something to suit ur needs!
FJ20ETs never had a twin scroll turbo standard , they used a small turbine series T3 in Nissan housings . Also the later DR30 RSXs had the higher compression pistons and the SMIC not the early ones . The later intercooled ones also had a slightly smaller 0.48 AR turbine housing in place of the earlier non intercooledand lower CR version 0.63 AR turbine housing .
Also there were two versions of the DR30 FJ20ET inlet manifold , the later one tapered down faster towards the back reducing the plenum volume which you'd think may make them pick up a little sooner than the early ones . I think I still have a few of my old FJ manifolds in the cave including the rare Gazelle FJ turbo ones .
My time with these engines was before Garrett sold integral waste gate T3 flanged GT30 turbine housings and in those days I always wanted a GT3076R/GT3037 but without the external waste gate .
If I had my time over I'd have a manifold made to suit the Evo Tens turbo mounting flange because Garrett make a bolt on GT3076R turbo for the and its turbine housing is twin scroll with twin integral waste gates , you even get a choice of 0.73 or 0.94 AR . With the generic GT3076Rs compressor housing it could make an effective if pricey hot side for an FJ20ET .
Lastly back to the CR business . FJs came from that ugly early 80's era where every know it all claimed you had to have a piss weak CR to avoid detonation with turbochargers . Most other engines of the day had pretty agricultural two valve combustion chambers and the manufacturers were too cheap to fit even small intercoolers ie Z18 Bluebirds 280ZX Turbos and even VL Turbos . The FJ20 was probably the first of Nissans production twin cam four valve heads with pent roof combustion chambers and these were a big leap ahead of any four or six pot L Series engine .
Off the top of my head the early FJ ET made about 147 Kw and the later RSX intercooled one approx 194 .
Both my FJs used the later higher (9ish) CR pistons and neither were really detonation prone .
A .
Disco really happy you are still kicking around the traps. Sorry brain fart re CR I've owned 5 fj's myself thanks for the info you posted. Early and late fj's had a 142kw 151kw respectively I believe with power mainly gained through the piddly intercooler and an extra 1-2 psi. Also quite sure was the first Japanese production 4 valve per cylinder head period. enough history lessons I think :P
I have two options atm. Modify an R34 GT-T Intercooler I have in possession to fit in standard location and bump boost up to 13psi on the sock turbo with its power chocking wastegate setup and be happy I'm retaining a stock looking engine bay.
But I've been offered a Japanese DR30 return flow cooler kit in exchange for a couple unwanted parts.
So this is why the topic title has been asked. I'm at this stage not interested in a high flow when I can get a hold of a Genuine Holset for the same money which have been proven to work well in many street applications if the right specs are chosen.
Edited by D-limo
Yes I think the head or valve train anyway was loosely based on the Formula Pacific competition only L Series head .
Personally I'd be wary of diesel based turbos for a two litre four banger , often they have big bulky housings and need external gates .
A real GT3076R would be interesting on an FJ20 and is probably as compact as a nearky 300 Kw turbo gets to be , using a IW one should be straightforward on a DR30 exhaust manifold .
A .
 Share
    • I have been looking at some setting on the alarms for the Q60 and what buttons do and so and also been looking for details on the alarm in my V37 which is a standard issue with the car. settings like window roll up and a few others seem to not work at all. i cant seem to find exact info on V37 alarms so Q60 is all i can really go off i have not tried 400Z alarm settings or info yet so that will be next. any one got like a sheet of info on the alarm system in the V37 as all my documents are in japanese but i thought the system would basically be like standard through similar models?
    • I had a fuel smell coming from the drivers rear and pulled the tank out to inspect where it was coming from, turns out the breather hose from the tank to the filler neck was perished. I’m going to Japan next week and I’ll grab it while I’m there  pulled the oil tank apart and started cleaning this crap out of it, some brake cleaner and rags got it looking new again
    • Hmm. Was quite a few years ago now. I think I bought from a crowd in the US called CDT Audio. The speaker is the HD-6. The HD-6CF would have been the better option (based on T-S parameters), but they were discontinued in 4 ohm at that point in time. The HD-6 is a better driver in almost every other way (than the CF) - just not as good in IB. They still do the HD-6. They might even have a more suitable (for IB) option here.https://www.cdtaudio.com/cdtnew22/products/components/woofers/midwoofers/midwoofers.htm But, here's the rub. I was working in the US a lot back then, so I got them delivered to my US office and then just brought them back to OZ myself. I don't know if they will ship to OZ, and it probably wouldn't be great cost-wise anyway. As to results. They're driven direct off the rear channels of my headunit, because the headunit can be setup to run the rears as subs. So, not a lot of power being fed there. Nevertheless, there's no shortage of volume - the sub levels don't need or want to be boosted at all. The bass is definitely not what you would call "tight". It is definitely a bit delayed compared to a proper sub. But, with the great front soundstage and really good 6.5" woofers in the front doors, I'm getting most of the bass detail from the front and the rear is really only to extend the bottom end a bit. Works for what I'm doing. I mean - until recently you couldn't really hold a conversation in my car due to the fuel pump, and for many years I had tyres so noisy (Kumho KU36 at <50 tread depth) that I had to drive with earplugs anyway!
    • curious to know what drivers you chose and the results? quik mafs, says two 6.5s should roughly equate somewhere between a single 8" or 10" driver. i agree that IB is definitely the way to go in most cars imo.
    • S13 and R32 rear suspension geometry is horrible once you lower it (which everyone does). The camber & toe out ramp is very aggressive, hence it's common for the S13 boys/girls to use a S14 or S15 subframe as the geometry is light years ahead. I'm sure the same can be done on R32s, but I don't know anyone that has done that.
