I think more threads like the dry sump one would be beneficial to create conversation and information.
Threads would have to be specifically Motorsport orientated.
Kinda like the Bruce ducting thread and the cooling thread that are going at the moment in other sections
  • Replies 56
well i was hoping to be apart of this new subforum but the car i was looking at buying was sold before i could look at it. :(
does anyone know of a clean caged r32 or r33 gtr rolling shell sitting around doing nothing?
there are always cheap shells rolling around...I'd talk to Brad or Fatz in the first instance, they both keep their ears close to the ground. An excellent 33 gtr roller with lots of good stuff was just sold cheap....but that doesn't really help you.
Ben, if it's just a case of editting the title etc I can do that, pm me the details, otherwise the easiest will be for you to copy into a new thread and make the changes
I have a 32R at work at the moment which is being parted out and the owner does want to sell the shell.
It's a touch rough around the edges and has a 4130 drag type cage in it. Could be cut out and Redone easily enough.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
