Ben, if it's just a case of editting the title etc I can do that, pm me the details, otherwise the easiest will be for you to copy into a new thread and make the changes
Cheers i'll just start a new thread in the Motorsport build section will be easier :)
  • Replies 56
there are always cheap shells rolling around...I'd talk to Brad or Fatz in the first instance, they both keep their ears close to the ground. An excellent 33 gtr roller with lots of good stuff was just sold cheap....but that doesn't really help you.
that was probably the one i was looking at..
I have a 32R at work at the moment which is being parted out and the owner does want to sell the shell.
It's a touch rough around the edges and has a 4130 drag type cage in it. Could be cut out and Redone easily enough.
i have a r32 gtr sitting here doing nothing too but i really want to build that as a street car.
i liked that r33 rolling shell because it had a cams approved roll cage and it had been compiled and previous registered with the cage in nsw and it looked really clean.
+ i have a r33 gtr donor car i could use for parts.
but i'll keep your car in my mind thanks.
I think more threads like the dry sump one would be beneficial to create conversation and information.
Threads would have to be specifically Motorsport orientated.
Kinda like the Bruce ducting thread and the cooling thread that are going at the moment in other sections
Where are these threads now as they are the exact sort if things that are motorsport orientated that we could all benefit from.
I've always thought your better off buying a clean road car and building a race car.
Road cars cost as much to build and they are worth nothing to buy already done.
I wouldn't buy someone else's race car unless I planned to strip it and rebuild it anyways. I see way to much patch up repair work to keep them running during the year.
They are all trashed, it just depends how well its been tarted up as to how good it looks.
I'd have no hesitation to buy that car if I wanted to build a track R33.
It's raw so you know what your starting with as opposed to a tidied up nugget, the engine needs to come out anyways for a sump etc so check it out internally.
80% of the interior is going in the bin.
The other caged 33 that was for sale was a bargain. Few and far between though.
tried that, no dice.
after a think about it i'm thinking i might buy something like a r32 gtst or a silvia and do one or two years worth of track days and learn how to drive and maintain a race car.
while i'm doing that i'll take what i've learnt and build my r32 gtr over time, i think that's the best way to do it (for me anyway).
now to find a r32 gtst that hasn't been tarted up with the help of ebay..
Good move having all the ms builds back in here!
Duncan when you get a moment photos are broken last page of my 32 build, and halfway in to first page of 34 build
http://www.skylinesaustralia.com/forums/topic/328473-pauls-r32-gtr-tarmac-build
http://www.skylinesaustralia.com/forums/topic/415094-pauls-r34-gtr-tarmac-rally-rebuild/
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
