So I bought a skyline last year, r33 n/a. A few days ago I drove a 32 gtr and I was wondering why my car doesn't pull like the gtr does? I mean... They're both skylines!
If anyone could help with this unknown extravagant myth, it would be greatly appreciated!
Probs cause it has a hyundai motor man, better get that checked, damn these grey imports!!
  • Replies 347
The sarcasm is strong with this one.
LOL! im not surprised =p Rb20e is probably = to a 1.3 litre yaris =p
I wouldn't be threatend if an rb20e r33 lined up my diahatsu.... I'd put money on the hatsu lol
i had a n/a r34, i was happy with it with looks, it was bayside blue and shit so in a way it was worth it for looks and handling, and even after 3 years and only 75XXXkm on it i only lost 2grand for what i paid and bought a wicked turbo one but that was pure luck how much i sold it for, in saying that. performance was so so so so so....... slow!! someone refereed to a camry, i think the toyota is faster. on a hot day it was embarrassing. if you want a quick n/a stay well away from the japs, if it has a turbo model, the n/a will most likely be very slow. there are some sleeper v6 cars out there like toyota aurions or in 4cyl mazda 3 sp25. the unexpected cars have the power. and as for cops, i hardly ever get pulled over on my opens even with a big fmic hanging out, but with p plates on a plain standard r34 i was rapped for ''rbt'' so they say. my advise is wait, buy a piece of shit and your turbo car. spend money on your turbo car so buy the time you get your opens you have had 3 years to build the car you want :)
OMG. It seems as though you do learn from your mistakes.
But no one listens to what we say.
I've never thought of owning an NA Skyline as a mistake. It may have been relatively slow but could still hold its own quite well on the day to day. Handles just as well as turbo variants and looks decent inside and out. It's not going to win any races but it's still a great experience.
Haha considering the fact that a rb20e only has around 100kw, thats a 0-100 time of 10 seconds ish. (from calculation of the 147kw rb25de 0-100 8 seconds).
Daihatsu however depending on what model average 9 seconds =p Ontop of that they are front wheel drive, andddd they are lighter! So yea by my calculations daihatsu will be the winner! What i dont understand is why nissan made a inline 6 when their 4cyl ca18 and sr20 surpasses it in power (n/a).
my 12r toyota engine is wicked fast.
faster than my gtr at the moment....
but lack of tuning parts means im looking at an sr conversion :(
But.... ATM your GTR gets beaten by a push bike lol
read the title, my $2.00 (cause N/A's always cost 100x more)
delemma with n/a rb's
stock = slow, but that'll do
a little modified = will want more eventually
all out nuts modifications - pig to drive down low
pushing it even further with sleeves and fj20 pistons and stroker cranks etc but eventually you will think and know its cheaper to drop in another motor which has double the power from factory and even have that engineered with plenty of change
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
