My Mechanic has just put in the new clutch and M & S cylinders but when testing the new clutch the pedal box cracked....
he is going to weld it up and put a strengthening bar onto it for now..
Any one upgraded their pedal box lately??
If so what/where/brand would you suggest???
Cheers :)
Cheers :)
Nismo do a reinforced clutch peddle mount.
GSL are the goods and remsa pads are getting a good rap from them lately
had remsa pads on for over a year now, even used on a track day, awesome street/performance pad
How u finding the dust with the remsa's ?
I find it average, but no worse than any other pad.
After a fairly long hills drive i get a loud screech coming from the front calipers, doesn't make a noise any other time.
Anyone got some good opinions on a comedy show to see while the fringe is on?
This looks good Luke....Habib & Rocky from Fat Pizza are in it.
Me and the missus are checking this one out Sat night with Shane & Co
http://www.adelaidefringe.com.au/fringetix/the-good-the-bad-and-the-ethnic/fc9f7e75-07ba-4784-b3d7-be563fdf5a17
I actually find brake dust is quite minimal unless you let it build up n don't wash your car for a couple of weeks
As for noises, I hear none. Perfectly quiet, even when cold
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
