Posted up on the Stagea Facebook group, figured this should be here too. Zeroed out my airbag light! FINALLY! Leon can stop worrying, since he broke it :nyaanyaa:
Turn the key to the on position and watch the airbag light. It should stay solid for 5-7 seconds, then turn off, then start to flash.
To reset the light, turn the key to on (without starting the car), watch the airbag light stay solid for 5-7 seconds, and as soon as the airbag light goes out, turn the key to the off position. You must make sure you turn the key to off before the light starts flashing, or you have to start again.
You need to repeat this 5 times, then start the car. You should see the light stay on solid for 5-7 seconds, then turn off.
The flashing airbag light should be no more! Apparently this is the same procedure the V35 guys use, and has worked for a couple of us now.
Good luck!
  • Like 1
https://www.sau.com.au/forums/topic/417451-fixing-that-damn-m35-airbag-light/
Hello Guys,
I had this bloody light issue for a while and after a while the key method just stopped working. .
I took mine to Mark @ Hills Motorsport in Hornsby and he fixed is no worries. .
Was a water damaged sensor thingy, most likely cause the leather detailer using too much liquid.
Apparently there are 11 SRS codes that prevent the airbags from deploying, and 9 that allow them to deploy. . . just a risk to guess which one. so I'm told.
FYI
What? If you are referring to your ham fisted attempt to install the cruise control, then LOL. :)
Mine has been flashing since I got my car. I don't even notice it now
I don't know what youre talking about...
Maybe try this to clear it, and if it reappears look into what Jules was saying?
Thanks for that info Jules, but I knew what caused mine - not clipping the wire on when I removed it to fit the cruise control. I fixed it, but the light doesn't clear itself even if there is no longer any fault.
the instructions have been on the M35 info forum for ages. just an FYI :)
True story, I've seen it.
No amount of turning the key off & on is going to help me. My car is missing the ram thingys under the front seats. Yellow clips are there but no explosive bits. I've tried the airbag delete, aka u-turn harness, but no fixy.
you could try and pull the sensors off one of the wrecks that are kicking around and fit them to your seat? They unbolt from the seat frame when you unclip the material cover and foam cushion
That ^, Dunc, is a sterling idea!
It all depends if anyone is willing to separate them from the seats for me (temporarily to try first I 'spose).
take the bulb out if all else fails
That would stop the annoying flash, but the lamp needs to be lit (& then extinguish) to pass rego check each year. I was thinking about a light on a timer circuit.
Nah, everyone in NSW is supposed to get checked every year (cars older than 5yrs only). But my comment was more for other people - I would look at something like that if required ;)
  • 4 weeks later...
  • 1 month later...
I soldered V35 yellow switch bypass modules in a few years ago when I fitted my Bride seats. I could never get the airbag light to clear with that method above, but my Consult III cleared it, no airbag light for a while now, looks promising.
Like Leon, I got so used to it I never noticed the flashing.
  • 7 years later...
Good luck!
This works a treat thank you!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
