Hi all, got a few queries with the instal of my plasmaman,
Firstly, I think I have a fairly old one, I got in second hand with t/b, reason I think that is it has an adapter place for aac valve instead of it bolting to side of plenum.
What I need to know is where to plumb things basically.
I run a haltech map sensor, To shorten the feed hose length should I tap into engine side of plenum half way up?
Where do I run the little hose that goes to the carbon canister from stock t/b?
Where do I plumb my pcv into?
Where do i get pcv from rb26 covers?
Im sure theres more ill think of but this is the main bits. Couldnt find much on the forums about these...
Thanks
https://www.sau.com.au/forums/topic/417808-plasmaman-fitment-questions/
Hmmm, my Plazmaman has like 7 fittings underneath.
Adapter plate is a little odd. The R33 IAC should bolt up to the rear of the Plazmaman? Unless the customer who ordered asked for something unusual like i did with mine... However, early models could have been done like this. I dont know.
If the MAP sensor is a 1/8" NPT thread you should be able to thread it into the Plazmaman directly.
With the PCV and RB26 covers, you'll have to custom make something. The PCV on an RB26 is on the balance tube of the inlet plenum. You'll probably want to have the LH rocker cover going into the turbo intake and the RH going into the Plazmaman via the PCV one way valve.
The little hose that goes from the carbon canister to the factory throttle body is a good question. I would also like the answer to this as i'll need to know eventually as well. I would dare say, it will need to go to the intercooler pipe just before the throttle body.
The larger pipe from the carbon caniser is plumbed directly to the plenum as well.
If you only have 3 fittings, before fitting the plenum maybe its a good idea to drill and tap some more holes in it.
You need provisions for:
Brake Booster
Fuel Press Reg
Carbon Canister
PCV
MAP Sensor
Boost Guage
Thanks kitto, ill have to tap fittings in at appropriate places.... id think the carbon canister tube off stock t/b goes to engine side as it'd actuate the diaphram in canister to suck on vacuum/close on boost?
This is my theory as well.
But if you have a look at where that little hose goes to on the throttle body, the hole pops up just barely on the intercooler side of the throttle body...
You can get manifolds with lots of takeoffs for various vacuum functions so you don't have to turn the plasmaman into a colendar.
Like this (some screw into the plenum some are just connected with a hose):
http://www.ebay.com.au/itm/ADD-Universal-Vacuum-Manifold-turbo-boost-vacuum-wastegate-intake-manifold-/110993986088?pt=Motors_Car_Truck_Parts_Accessories&hash=item19d7c1d228
And don't most people just bin the carbon canister?
Its not the smartest idea to delete the Carbon Canister. The only annoying thing about it is that it takes up space.
The larger tube is connected directly to the plenum, this is where the vapours enter the engine from the canister.
The smaller hose is to open the one way valve under vacuum and light throttle conditions. Why it is placed exactly where it is on the tip of the throttle plate i am unsure.
On R34's there is a solenoid inline with the small hose. From the canister the small hoses goes to the solenoid valve, then to the plenum. It's operated by the ECU. Obviously the ECU chooses the best time to open the valve. IE, the valve is open all the time until atmospheric pressure and above is reached.
Sounds like it may not be a plazmaman and instead one of the chinese knock offs?
Definately a plasmaman. just has 3 1/8 bsp holes near t/b and 1 3/8 bsp toward back for aac valve. Might tap 1 in middle for map and plumb booster into aac line
Brake Booster
Fuel Press Reg
Carbon Canister
PCV
MAP Sensor
Boost Guage
I believe that Plazmaman used to release the plenums with the AAC mounted onto the actual plenum itself but changed the design to a remote AAC block so as to not interfere with fitment of larger injectors? The block allows a certain degree of freedom when mounting the AAC (provided your lines and wires are long enough).
Ok, so started fitting it, finally. going to tap into it for the map, and booster so to reduce the length of lines. The carbon can lines can go to existing fittings on plenum.
Got a question, where the fast idle valve connects to plenum underneath in same place as stock one does, can I tee the aac remote line into the fast idle valve hose without issues? Couldnt see it harming idle.
Results!
From stock manifold to plazmaman with exact boost, went from 260kw to 270, and was last done in winter on a 20 degree day and new one 35+ and very humid. Thats at 16psi, when we went to high boost (23psi) there was not a great power gain but the power curve held hard to 7400, whereas peak prior was at 6000,, not quite back to back but a good guide.
dyno says losses in midrange. But air temp may play a large part. 20 degrees vs 35.... Its moved the power 200 revs up the range, but its got such a nice power curve now, was like a 2 stroke lol, and feels so smooth now and also makes a massive amount of intake noise when its coming on boost just under 5k.
And I just realised 1 more factor, Im running a 100cell cat, whereas wasnt with last one, so taking all into account, maybe midrange is better now?
Plus there was a fair amount of wheelspin on dyno this time. got new p-zero's and they are like jelly.
After comparing charts, my old printout had a peak of 338kw at 6k, where now it peaks at 7400 326kw, at 6k I only have 285kw.
The tractive effort has gone from 8000n to under 7000n. Still to take into account temps were way hotter, and humid, and running cat.
It feels very seamless power wise and feels to pull harder, is it possible to have gained torque even though tractive efforts gone down?
Dyno seems to say less, but I feel more..
Unless you do a back to back dyno with only the plenum changing you probably shouldn't waste any time looking at the old dyno plot. If the seat-of-pants dyno tells you it is better with the plenum, then one of two things is true. 1) It's placebo, which does happen, or 2) the car has either lost real power since the last dyno, or it is just the weather and cat causing the difference. Impossible to know unless you can back it up with some more testing.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
