Awesome - sounds good, so it has met your expectations without even leaning on it then? Hope the power delivery/response is good too :) I had figured it could be good for 450kw+ @ hubs on the right setup, but Dyno Dynamics are a bit of a mystery to me - never had any direct exposure to them so really I wasn't sure what to expect on one of those, though I had expected 370kw should be pretty doable.
Wow so it's not going to be driven at all until race day? No pressure :mellow: Hope it all goes well!
  • 1 month later...
Back to the FP3794HTA - apparently Forced Performance have a prototype "FPxx94HTA" which uses the same compressor wheel as the FP3794HTA but has different housings and a different turbine wheel, the initial indications are that it is expected to spool quicker than the current PT6766 and FP3794HTA - but make more power than either.
The car that the testing this thread is about has had one of these units attached to it and will be getting it tuned soon - and no doubt they won't be holding back. if it If it does turn out to be a better all around performer than the best of the 6766 and 3794 combined then it is a hell of a thing :)
It is Boostin' Performance's AWD Eagle Talon - it runs a high compression 4G63 with lots of headwork etc etc. It has run into the low 8s at >170mph (ie, quicker and faster than plenty AWD cars with GT42s/GT45s etc have run) with both the PT6766 and the FP 3794HTA, so it is a good base for taking such a turbo to it's limit :)
  • 3 weeks later...
  • 3 weeks later...
More on this GT3794R HTA prototype, it is now released as the Super94HTA and apparently spools better than and makes more power than both the PT6766 and the GT3794R HTA... it has been tested on a Mitsi AWD drag car which has run the previous turbos and on a slippery track this weekend it ran 8.4 @ 177mph - huge MPH for a car running a T3 based turbo.
So anyone certifiable who was looking for something in the 6766/3794 size range - they are now available to buy:
http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTFPSUPER94&Category_Code=Turbo-FP
  • 4 months later...
First 7s car I am aware of running a single T3 turbo, using a .85a/r FP Super 99HTZ:
And an AWD DSM ran a 1000ft test run this weekend and lifted to hit 8.2 at 153mph also using an HTA - they only had an 8.5 certified cage and had suspected they MIGHT go too fast, hence lifting at 1000ft.... but were kicked out due to still going way too quick. Seems like there may be a couple of 7s AWDs and a number of low 8s ones running these turbos in the near future :)
Agreed, just pointing out it is still a large turbo - but it is SERIOUS business... especially when no one has pushed a 99HTZ to it's limits, yet.
  • Like 1
A Supra owner in the US has upgraded from their old Borg Warner S467 T4 turbo to a T3 flanged FP Super99HTZ and picked up 15% more power with a huge increase in spool - they run a Powerglide and usually use a transbrake however they are testing for an event this weekend where the class they will be in doesn't allow transbrakes, so they did testing using a foot brake starting at low boost to see how much they could hold back with the foot brake and have already laid down a 8.97 @ 151mph... I suspect when they get to a meet they can use the transbrake and wind up the boost a few eyebrows will be raised - not that running 8s on a T3 based turbo with a Supra isn't pretty unreal as it is!
  • Like 1
Not with the new turbo yet, today it was it's first runs - the turbo seems to have maxed out at about 36psi (with 280deg cams) but I don't know what boost it was running for the 8 - definitely not 36psi.
Here's a dyno vid (unfortunately they only uploaded to FB): https://www.facebook.com/photo.php?v=194348620749465&set=vb.173984302785897&type=2&theater'>https://www.facebook.com/photo.php?v=194348620749465&set=vb.173984302785897&type=2&theater
Dyno numbers will be a bit messed up due to the loose Powerglide - but a Supra running 8s at >150mph is going to be making north of 900hp to start with, it isn't running NOS and it did it off the foot brake with more boost in it.... so safe to say that it's already a pretty stout result :)
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
