  • Replies 297
Some should be excluded though, yourself, Nick and Simon. No one on here will beat Ghosty at this challenge, or most challenges
No one is excluded.., "most challenges" hey.. I'm sure I can think a few challenges that wouldn't be so one sided.... Apparently
Only problem is im a sook and my hands get rooted from work as a cabinet maker/installer so i use wraps to ease the pain and damage. Otherwise id do it, as its deads day for me today.
if I could edit the original post I'd add those excuses next to the coil pack issues.
says the guy who also says "not competing yet till I get a little stronger"
lol
It was more to do with the first doable novice comp being around April/May - incidentally enough time to gain some strength. I'll compete anyway, I just hope to be stronger by then.
Sounds like fun! I don't really care about the winning part. Any challenge can be applied against yourself.
Hard choice on the percentage vs standard weight because.... Well I have put on weight since I started gym and most of it is fat weight. Anyway!
I'm cool without gloves but is chalky chalk ok?
chalk is always welcome
Might have to look into this more.
I currently weigh in at 84kg ,
Was zapped today from heat, no excuse though i thought i preped before gym well. I believe there is plenty of room for improvement on that effort. I will see if i can get a video tomorrow when little less busy.
So is this a 1.5x bodyweight or 100kg? was it decided?
My deads today included a set of 145kg for 12 reps. @ 96.5kg. My first deads in a very very long time....
I think I'd like to do 20 or so reps of 145kg before the end of Jan, hopefully I can vid the success in the next week or so.
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
