  • Replies 297
Some should be excluded though, yourself, Nick and Simon. No one on here will beat Ghosty at this challenge, or most challenges
No one is excluded.., "most challenges" hey.. I'm sure I can think a few challenges that wouldn't be so one sided.... Apparently
Only problem is im a sook and my hands get rooted from work as a cabinet maker/installer so i use wraps to ease the pain and damage. Otherwise id do it, as its deads day for me today.
if I could edit the original post I'd add those excuses next to the coil pack issues.
says the guy who also says "not competing yet till I get a little stronger"
lol
It was more to do with the first doable novice comp being around April/May - incidentally enough time to gain some strength. I'll compete anyway, I just hope to be stronger by then.
Sounds like fun! I don't really care about the winning part. Any challenge can be applied against yourself.
Hard choice on the percentage vs standard weight because.... Well I have put on weight since I started gym and most of it is fat weight. Anyway!
I'm cool without gloves but is chalky chalk ok?
chalk is always welcome
Might have to look into this more.
I currently weigh in at 84kg ,
Was zapped today from heat, no excuse though i thought i preped before gym well. I believe there is plenty of room for improvement on that effort. I will see if i can get a video tomorrow when little less busy.
So is this a 1.5x bodyweight or 100kg? was it decided?
My deads today included a set of 145kg for 12 reps. @ 96.5kg. My first deads in a very very long time....
I think I'd like to do 20 or so reps of 145kg before the end of Jan, hopefully I can vid the success in the next week or so.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
