  • Replies 297
there was no rest(if you call that resting you have to be kidding yourself), there was no bouncing(the weight stopped before he lifted again), and it was lowered under control(dropping the bar out of your hands is out of control, lowering down really slowly is not 'under control', it's stupid and will do you damage).
Awesome effort, will have to try for 38
ill keep this in mind for next effort then
Oh, and in case some on here dont know
I'm President of a PL Fed
I own another Fed
I own a PL gym with over 30 competing lifters
I started a PL gym franchise that has gyms in 4 states
I've been to PL comps on 3 continents
My lifters have 94 World Records
I first started judging PL comps in 1991
I know what a deadlift is lol
Some pretty good efforts from you non competing guys to, its great to see guys deadlifting in commercial gyms
I think the next challenge should be bench bw for reps, EVERYONE benches, some on here would give competition guys a run for their money
I dont think my guys excel at bench bw anymore than regular gym goers
Back day today. Guna hit this up and see what i can muster.
I can dead about 260kg with straps for 1RM.
But holding onto 150kgs for around 20 or more reps with no straps is guna kill me (im not a power lifter lol).
Only time will tell.
You can do it !!!
ok so 125kg @ at about 84kg (lost some weight at some stage over the last couple of weeks :/)
Height 6.1
couldnt find any chalk and nearly fell backwards on the first rep lol
19 reps
Far out man. Top effort.
I'm not gonna try this because 1.5BW deadlifts are a challenge altogether for me. Not to mention going for reps lol
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
