Hey guys I am located on the Gold Coast, willing to post items at cost or pick up and currently have the following for sale;
(Prices Negotiable)
R32 GTR Passenger seat Immaculate condition, with rail, all movements working perfectly $280
Also have a std R32 Gtst drivers seat laying around in good condition for $40,
polished dished Work Equips 18"x10+28 fronts, 18"x11.5+24 rears $2200 (tyres very poor)
post-44496-0-11981500-1354438815_thumb.jpgpost-44496-0-12466200-1354438830_thumb.jpgpost-44496-0-65374500-1354438835_thumb.jpgpost-44496-0-78718400-1354438841_thumb.jpg
HKS Super dragger 3.5" exhaust cat back to suit R32 chassis and twin front pipe to suit rb26dett will separate or $500ono the lot excellent condition polished cannon 5"
Momo steering wheel in perfect condition, also have an immaculate genuine horn button to fit. Steer wheel $130, Button $20 post-44496-0-95102800-1354439884_thumb.jpgpost-44496-0-94130200-1354439892_thumb.jpg
Pwr FC hand controller $300 late model pwr fc
R32 drivers door control switch board perfect condition $50
R32 GTR front left driveshaft perfect condition, good cond boots $100, also have transfer shaft from gearbox to front diff and tailshaft $100
Rb26 starter motor $60
HKS 2530's $2000 pair turbos only, done 2000kms also have oil drains, lines, std dump and manifolds etc enquire for price
post-44496-0-29139600-1354439251_thumb.jpgpost-44496-0-88160400-1354439268_thumb.jpgpost-44496-0-00615300-1354439288_thumb.jpgpost-44496-0-46621000-1354439293_thumb.jpgpost-44496-0-82637500-1354439300_thumb.jpg
Tein Coilovers to suit R32 GTR and GTS4 $750 very good condition no leaks, heavy spring rates of I think 12kg and 10 kg height adjustable go very low, and damper adjustable, have genuine spanners to suit
post-44496-0-87689600-1358738950_thumb.jpgpost-44496-0-95886400-1358739017_thumb.jpgpost-44496-0-64021400-1358739042_thumb.jpgpost-44496-0-88991600-1358739068_thumb.jpg
R32 Japanese Fibreglass front vented guards good condition $250 with mesh in vents (not cheap local made, these are durable jap guards)
SKYLINE door skirt trims great cond.$50pair
R32 skyline floor mats genuine original $60
RB26 Coil Pack loom excellent condition $100
D1 SPEC racing lightweight nuts in blue x 20 $30
Bolt on fenders 1 pair fronts and one pair rears are roughly 30mm guards with rubber trim and polished capped nuts $120
R32 windscreen trim plastic piece great condition $30
R32 clutch master cylinder clean and perfect working condition $60
R32 handbrake complete, good cond. leather $60
R32 abs model master cylinder, clean great working condition $80
R32 GTR (also fit gts4) ABS module excellent condition no leaks $300
R32 'A' Pillar Trims, left and right side, excellent condition have all clips $30ea
R32 m spec fog lights (can make to suit anything) excellent condition $50
R32 Tail lights $100 pair
Bosch 023 fuel pump custom fitted to R32 fuel pump cradle and sender complete unit $140
R32 boot lid and genuine N1 lip, professionally painted and wing holes filled in $300
R32 gtst front brake rotors, pads and vented slotted discs, excellent condition pads and discs only used for 10000km $250 pair front left and right
R32 GTR front hubs and wishbone complete left and right side, $100ea
R32 gtr (will also fit gts4) gearbox crossmember $40
R32 horn and bonnet catch support $50
R32 gtr rear seatbelts pair, great cond. $60
R32 front strut brace has had part machined out to clear crossover pipe on rb20/25 $30
R32 GTR front transfer shaft, gearbox to front diff, great cond. $80
apexi turbo timer perfect working condition $20
R32 dash surround $30
Rb26 engine loom good condition from r32 late model $150
Names Johnny I would rather you call or txt, otherwise please PM, thanks
0414596256
Edited by slidinr32gtr
Hey mate txted you about the door sill/ kick plates but you didnt reply are this still for sale if yes id like them thanks :)
  • 4 weeks later...
  • 4 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
