hi, I have got some r32, r33 engine parts for sale. also some rb30.
rb20det crossover pipe x 3
rb25det crossover pipe x 2
rb30 crossover pipe x 2
rb20det stock bov x3
rb25det stock bov x 2
rb25det air compressor bracket has been soda blasted
rb25det hicas p/steer pump
rb25det non hicas p/steer pump
rb30e na camshaft gc
rb30 na starter motor x2 (auto and manual are the same)
rb20det starter motor
rb30 stock cam gear
rb25det sII stock cam gears
rb25det p/steer reserviour
rb25det polution canister
rb25det cas bracket
rb20det stock dump pipe x 2
rb25det stock dump pipe x 1
rb25det oil pump
rb25det oil filter cooler sandwich plate x2
rb20/25det stock exhaust manifold x2
rb20/25det exhaust manifold heat shield
holden rb30 rocker covers
tridon rb30 thermostat. used for maybe a week max
rb25det neo cam covers
internal fuel pump r32/r33? jecs
rb20/25det thermostat housing/lower hose to block pipe x 3
rb alternator slider bracket x2
rb30na heat shield
factory vl turbo A8 pistons and rods x6
rb30na exhaust manifold down to cat
p/steer pump brackets
neo engine cover bracket
rb25det neo rocker covers
rb25det bare intake manifold $15
rb30 sump
r33 rb25det cooler hoses
stock sII rb25det injectors
Stock sII rb25det coilpacks
Call Jamie. 0433 559 722. pick up from rothwell, brisbane northside 4022
Edited by gold-3lt
https://www.sau.com.au/forums/topic/418685-skyline-parts-rb20detrb25detrb30/
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 1 month later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
