Awesome stuff, damn fast groceries, keep up the good work.
How's the drive line holding up ?
We have done our own 4wd auto and it has decent axles. The driveshaft from transfere case to front diff is stock, the rear diff is stock R32 GTR and the front just has a 1.5 way lsd in it.
All seems to love it so far but we havn't really layed into it power wise yet.
Just need to get the 60fts sorted then we should be on for sub 8.50s
Rob
Rob
Are you just using the gas to help it spin up, and get it off the line?
Think you might need some bigger brakes, or convince them to put a bit more tar down :P
Definitely is an average track with all those hills on it :D
Top work as usual by Rob at RIPS.
Only thing left on the car that is Stagea is the shell :D
Lol, you'd be surprised how much is still stock stagea.
All we need now is to get the whole deal into a 1100-1200kg GTR, "on paper" (which is quite often different to reality as we both know) thats a potential of 7.90s @ 180 with the same power we used on the weekend.
Edited by R.I.P.S NZ
  • 3 months later...
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
