I'm just about to gain ownership of the d2 8pot 356mm big brake upgrade on the front of my r32 gtr, with the increased piston surface area at the front i'm guessing it will largely change the brake bias in my car? I understand that my gtr has 38mm pistons in the rear, and the (r32vspec, 33, 34) are an amolst straight bolt on with a larger 40mm rear pistion and slightly larger disc.
Would the larger brembo plus larger disc be worth my time or should i opt for some thing else, my car will see a fair bit of track work.
Also an upgrade in the master brake cyclinder would greatly help?
Thank you Elliot
Edited by geetea-are
Piston area has little to do with it. In fact, given that these calipers are intended to be put onto cars without any changes to the master cylinder (or necessarily any change to the rear brakes), I think you'll find that the 8 little pistons don't have a very different total area than the 4 bigger ones in your existing calipers.
The difference in braking power comes simply from the extra torque created by moving the contact circle radially outward from the hub. The same braking force applied to the disc multiplied by the longer lever arm = more torque.
On that basis, given that you are increasing the front braking ability by quite a reasonable amount, then yes, putting at least the 330mm kit on the rear would probably be a good idea. If you were to look on D2's site, you would see that they do mildly recommend that you match upgrades at both ends.
Do not consider the Vspec rears to be an upgrade that you would notice the effect of. The changes are really too small, and they were intended to work with 324mm front rotors. Hence why I suggested you would go for at least the D2 330 rear equivalents if you were to do anything.
If you are just aiming for your club level track day
Front Upgrade
Stock rear
Stock Master Cylinder
It's what most people do, and it works fine.
Rear upgrade isn't required unless you need more heat dissipation capacity from the larger rotor etc - only needed in a totally dedicated track car that's aiming for LOT of laps and 15mins+ running time (which is well over & above your club level sprint days).
You're doing it wrong. Very very wrong. You have to square the diameters to compare them. Area is not the same as sum of diameters.
Area = pi*(d^2)/4
4 x 40.44mm pistons has total area = 5127.582mm2.
4 x 26.4 + 4x 31 mm pistons has total area = 2189.564 + 3019.071 = 5208.635 mm2 which is 1.5% more than the original calipers.
ahh that's what I was about to say :) D2 piston area is almost identical to standard although the disc and caliper is much larger. So they are a great swap with no impact on front/rear bias :)
I wouldn't bother changing the rears in any case, you just change the pads to be more or less aggressive if you want to change the front/rear balance a little. No need to change the caliper and disc they are already adequately large in almost all use
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
