  • Replies 41
I look forward to your work.
Isn't it funny how when you look at a woman's face, it can look like a million dollars. I like just that single face - and then captured with "that look".
Megan always looked to me like a million dollars. I don't like putting her next to Jennifer who looks like a million dollars > Megan then looks like $990,000.
Thought I'd make the most of the beautiful Queensland weather we are having at the moment to get off my ass and go take some photos
Needed another dark filter or two to make this work how I wanted:
IMG_3917 by 89CAL, on Flickr
Got lucky and appeared at the right place at the right time. This one is pretty much as shot:
IMG_3886 by 89CAL, on Flickr
And one more:
IMG_3903 by 89CAL, on Flickr
Thanks Dan, this was actually my first attempt at panning in ages! I can't even remember the last time I tried one - maybe the drifting after WTAC 2011???
I also shot this the same night:
IMG_6562 by Autocult. Network, on Flickr
BTW, love that shot you posted too - great framing, smooth bokeh and great, even lighting. Nice looking girl too!
Thanks man. The whole shoot lasted 5 mins. It was super windy and it wasn't easy keeping the camera still. Got the pic I wanted and we drove off
And one more:
did you use an ND filter for this?
Yeah used an ND and polorasing filter to try and bring the brightness down to take a longer exposure. Would have been nicer if I could have made the exposure longer then I did but just wanted to have a go. Want to go do a night/twighlight shot one day. will see how i go :)
I'll pay that. Both technically correct and a quality comment.
What I did mean was: what was the propellant? What did you use to move it around? IE: rag on a stick...
Why are you LOL'ing for?
a magician, his secrets, etc etc
I would also like to know though
Your on the right track, I'm keeping the details quiet for a while though, til I use it for a print shoot at least. I've been experimenting with fire for the best part of a year now, I want all that time wasted to have some impact before everyone starts doing the same shit and it gets old.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
