Hey guys I have an R34 GTT and when I turn on my aircon my revs drop massively, causing my car to stall at lights and such. I disconnected the AAC Valve and connected it directly to 12v with the aircon on and the revs will jump up to 1200 from ~550rpm. Which is where it should be sitting. I have checked at the ECU and it doesn't have any power coming out to the AAC. Even though with the scan tool it says AAC at ~100%.
The car has some weird rev drop when I start the car even if the aircon is off.
Any ideas would be appreciated!
https://www.sau.com.au/forums/topic/419347-aac-valve-not-getting-power/
Check for 12V at the AAC plug. Should have constant 12V on one pin with the ignition switch on. ECU controls the ground for the AAC using a PWM output when the engine is running
AAC valve itself could be faulty.
After looking at the wiring diagram if the AAC doesn't have power, the Canister purge control valve, variable air intake control solenoid valve, turbo pressure control valve and air jet swirl control valve shouldn't have power either?
The AAC Valve itself is fine. I tested it by running 12v directly to it and the revs picked up drasticaly.
For some odd reason when ignition is on it has 1.4v once the engine is running with A/C on it has 0.01V????? What is going on here!
Edited by sirjb
After looking at the wiring diagram if the AAC doesn't have power, the Canister purge control valve, variable air intake control solenoid valve, turbo pressure control valve and air jet swirl control valve shouldn't have power either.
Correct, but if its just the part of the loom that controls the AAC valve that is damaged then only the AAC valve won't work.
I'm not sure if that circuit is powered from a dedicated fuse? Quite possible 'Engine Control' Fuse at 10A? I'm not familiar with the body loom of an R34, only the engine side of things.
02 Sensor won't have power either, the air jet swirl valve and variable intake control valve would only be on DE's i would say.
So I got a good multimeter from work and did some testing. When the ignition is switched to 'on' with the engine off, there is 12v to the valve, but there is no ground continuity. Once the engine has been started the 12v disappears and the continuity of the ground is all good. SO for some reason the 12v is dropping out once the engine is running, any ideas?
Edited by sirjb
  • 1 month later...
  • 1 year later...
Hey guys, Well it looks like my aac valve isn't working correctly or God knows what it is, I apply 12v to the solenoid and nothing changes, I also have a spare solenoid here and when I apply 12v to it nothing happens??? is it meant to move in and out or something? please let me know asap, thanks.
Complete circuit (12 V source to solenoid to ground)?
pull the solenoid off the valve and have a look. You should feel it work if you hold it while applying and removing 12v, its only held on with 2 little screws
Because they work off frequency (PWM) you will not be able to do much more then see if it functions. It shouldnt matter which pin you apply 12V to, as long as it has a circuit to ground on the other pin.
Hey man thanks for the quick reply, yeah I apply a positive to 1 pin and 1 negative off my booster pack onto the pins and nothing happens and I can't feel it doing anything, or do I have to do it with the car power so that I can put a earth instead of negative if that makes any difference? thanks.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
