Hey guys I have an R34 GTT and when I turn on my aircon my revs drop massively, causing my car to stall at lights and such. I disconnected the AAC Valve and connected it directly to 12v with the aircon on and the revs will jump up to 1200 from ~550rpm. Which is where it should be sitting. I have checked at the ECU and it doesn't have any power coming out to the AAC. Even though with the scan tool it says AAC at ~100%.
The car has some weird rev drop when I start the car even if the aircon is off.
Any ideas would be appreciated!
https://www.sau.com.au/forums/topic/419347-aac-valve-not-getting-power/
Check for 12V at the AAC plug. Should have constant 12V on one pin with the ignition switch on. ECU controls the ground for the AAC using a PWM output when the engine is running
AAC valve itself could be faulty.
After looking at the wiring diagram if the AAC doesn't have power, the Canister purge control valve, variable air intake control solenoid valve, turbo pressure control valve and air jet swirl control valve shouldn't have power either?
The AAC Valve itself is fine. I tested it by running 12v directly to it and the revs picked up drasticaly.
For some odd reason when ignition is on it has 1.4v once the engine is running with A/C on it has 0.01V????? What is going on here!
Edited by sirjb
After looking at the wiring diagram if the AAC doesn't have power, the Canister purge control valve, variable air intake control solenoid valve, turbo pressure control valve and air jet swirl control valve shouldn't have power either.
Correct, but if its just the part of the loom that controls the AAC valve that is damaged then only the AAC valve won't work.
I'm not sure if that circuit is powered from a dedicated fuse? Quite possible 'Engine Control' Fuse at 10A? I'm not familiar with the body loom of an R34, only the engine side of things.
02 Sensor won't have power either, the air jet swirl valve and variable intake control valve would only be on DE's i would say.
So I got a good multimeter from work and did some testing. When the ignition is switched to 'on' with the engine off, there is 12v to the valve, but there is no ground continuity. Once the engine has been started the 12v disappears and the continuity of the ground is all good. SO for some reason the 12v is dropping out once the engine is running, any ideas?
Edited by sirjb
  • 1 month later...
  • 1 year later...
Hey guys, Well it looks like my aac valve isn't working correctly or God knows what it is, I apply 12v to the solenoid and nothing changes, I also have a spare solenoid here and when I apply 12v to it nothing happens??? is it meant to move in and out or something? please let me know asap, thanks.
Complete circuit (12 V source to solenoid to ground)?
pull the solenoid off the valve and have a look. You should feel it work if you hold it while applying and removing 12v, its only held on with 2 little screws
Because they work off frequency (PWM) you will not be able to do much more then see if it functions. It shouldnt matter which pin you apply 12V to, as long as it has a circuit to ground on the other pin.
Hey man thanks for the quick reply, yeah I apply a positive to 1 pin and 1 negative off my booster pack onto the pins and nothing happens and I can't feel it doing anything, or do I have to do it with the car power so that I can put a earth instead of negative if that makes any difference? thanks.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
