Hey guys, I've just started wrecking a white series 2 R33 Skyline Gts-t here in Sydney.
It was running great before it went for a slide on a wet night and the front corner and rear quarter licked a guard rail
Chuck me a message or reply here if you're after anything - it had some dead sexy wheels and a few mods listed below:
Pickup fine in Sydney or I can send most parts anywhere in Australia
post-35556-0-62431100-1360126947_thumb.jpg post-35556-0-71167200-1360126966_thumb.jpg post-35556-0-67637500-1360128006_thumb.jpg
Aftermarket stuff:
Set of 4x Enkei AME Circlar Spec R matte black wheels and tyres - $2200 ono
Fronts are 18x9" +15 offset, rears are 18x10" +15 offset. Fits R33 gts-t without spacers and looks great, perfect for GTRs also
Tyres are Federal SS595 all round, stretched 225/40 on the front and 235/40 on the rears. Lots of tread left - 70%+
All the rims are in immaculate condition, basically no gutter scrapes to speak of at all. No stains on the silver or scratches on the black centres
post-35556-0-87489300-1360127017_thumb.jpg post-35556-0-70239200-1360127079_thumb.jpg post-35556-0-03173500-1360127091_thumb.jpg post-35556-0-08582000-1360127150_thumb.jpg
post-35556-0-55394300-1360127029_thumb.jpg post-35556-0-17191300-1360127036_thumb.jpg post-35556-0-81501700-1360127055_thumb.jpg post-35556-0-65771400-1360127063_thumb.jpg
Kics Racing Composite R40 - Wheel Nuts & lock nut set. Great condition, looked awesome on the above wheels - $100 ono
BC BR height and damper adjustable coilover set, includes C-spanners. As new condition, weren't in the car long - $900 ono
post-35556-0-96443100-1360127282_thumb.jpg post-35556-0-13133900-1360127291_thumb.jpg post-35556-0-13652600-1360127299_thumb.jpg
Hardrace adjustable front castor/tension rods. Great condition - $120 ono
Hardrace adjustable upper camber arms. Great condition - $120 ono
Nardi deep corn 350mm steering wheel + HKB bosskit (airbag/hicas compatible) & horn. $250
Immaculate condition, like new, was only used for a couple of months before the car stacked it. Have the receipt ($375 for wheel alone) and box
post-35556-0-51258800-1360127649_thumb.jpg post-35556-0-78498000-1360127684_thumb.jpg post-35556-0-70658700-1360127693_thumb.jpg
Cooling pro stealth return flow FMIC & polished piping kit, suits R33 Gts-t & R34 GT-T
Good condition, includes all pipes and hose clamps/joints. Small ding/scratch on one side, does not affect anything - $350 - pickup only
post-35556-0-41282100-1360127734_thumb.jpg post-35556-0-10750800-1360127805_thumb.jpg
Splitfire coil packs (SF-DIS-005) suits Series 1.5/S2 R33 Gts-t (with no ignitor) and R34 GTR - $400
Triple gauge cluster with smoked-face Auto Gauge gauges (boost, oil temp, water temp) Looks great lit up - $150
clips/fits right into the R33 Gts-t dash into a DIN slot. Includes all wiring, hose, water temp sensor. Second photo is with the flash on so you can see the faces
post-35556-0-35573400-1360128411_thumb.jpg post-35556-0-83920000-1360128418_thumb.jpg
Monza Oil Catch can - $40
Apexi pod filter, bolts right up to most Nissan AFM - $50
The engine has approx 120,000k's on the clock and ran great. Timing belt was replaced by Unigroup at ~94,000km in 2010
I did a compression test this week and it came up great - 150-155psi on all cylinders - chasing $1k ono for the bare engine (no turbo, coils, accessories, etc)
5 speed manual gearbox was running great as well, shifted nicely. Regularly serviced along with the engine - $1300 ono with tailshaft, shifter, crossmember
I can also sell it as a whole manual conversion for $1500 (with pedals, flywheel, clutch master & slave cyl, etc
Exterior Stuff:
headlights, front bar, reo not available
s2 front bar foglights/inducators (white) - $120 pair ono
Front guards - $75 each
Bare nose cut/radiator support - $150
Side mirrors - $40 each
Tail lights - $40 each
Standard sideskirts & rear pods - $150
boot lid & s2 spoiler, immaculate condition - $150
Engine / Engine bay stuff:
Aircon condenser - $150
R33 aircon compressor pump - $100
R33 power steering pump - $100
R33 alternator - $100
Series 2 (no ignitor) Rb25det engine loom - $150
S2 afm (pink sticker) - $90
Engine Mounts - $70/pair
Fuse box lid - $20
Radiator overflow bottle - $20
Washer bottle & motors - $25
BM44 ABS brake master cylinder - $50
Standard fuel pump - $40
Brakes/driveline:
Front calipers, with basically brand new pads - $280
Rear calipers, with basically brand new pads - $130
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Front lower control arms - $70 ea ono
Front upper control arms - $50/pr
Front 5 stud hubs - $50 each
Rear lower control arms - $40 each
Rear 5 stud hubs - $130 pair
Handbrake drum assembly incl cables - $140 pair
Rear differential (4.1) manual diff - $250
Driveshafts $75 pair
Spare space saver wheel - $50
Interior:
Complete set of floor mats, good condition - $80
S2 Front seats, great condition, small bit of wear on the driver's side in the usual area - $120 - pickup only
Complete set of S2 door trims, great condition (x4 pieces) - $100 - pickup only
Passenger side window motor - $50
Drivers side window motor - $100
Instrument cluster, approx 120,000km, all gauges working - $120
Instrument cluster dash surround - $100
Centre console, with good lid/latch - $50
Seatbelts (full set) - $75
Ignition barrel + door barrels & key - $90
  • 4 weeks later...
  • 5 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
