Overnights parts from Japan
This is a Xmas Present from the Wifey. So probably won't be putting them on until then!
These are Quest LED lights (Nismo style)
Got these through a fellow SAU forum member elrodeo666. Good price, quick and easy to deal with! Would recommend!
And a pic from the weekend. Estblshd & PAC Paul Walker Charity Meet
On 12/29/2013 at 7:00 PM, TM7GTR said:
Came up real nice :thumbsup:
Are you going to get a gtr reo to see if that closes up the bonnet-bar gap?
…keen to see if it does so I can then do the same!
Yup have already ordered the GTR reo from Japan should arrive in Jan, and fingers crossed fitted late Jan/early Feb
Also fingers crossed I have time to fit this on in the next few weeks.
It's a ATR45 turbo that is the same specs as a 3582 from a XR6 Turbo. Should solve my turbo restriction issues
1483322-779148325432862-384697661-n-7791
Just read through this, massive transformation, looks great! Still planning on tracking it?
Yup thats still the plan. Fingers crossed can track it for the full 2014 year
Things to go on within the next two weeks:
1. 3582 Turbo
2. Better intercooler piping bend
3. Shave off a bit of the suspension arm so I can fit my hankook rs3
4. Try and fix rubber heater hoses that are touching the manifold
5. Oil cooler + thermostat
Then will just need to look at a some suspension maintenance and a wheel alignment and the she should be set!
  • 3 weeks later...
So in for a tune on the new turbo.
But there is an underlying problem with the car. At this stage it may be the injectors. So we are going to pull them out and flow test them
In coming to this analysis we switched to e85 fuel, so will probably just stick with e85 fuel.
At this stage the car makes 315rwkw at 4,500 rpm. Trent thinks it will get close to 400rwkw once the issue is fixed.
TBH 400rwkw seems way to much power for me to handle. So will see how it goes!
Didn't build anything on the weekend
Just got a car wash so its slipperier through the air and faster on the straights :ninja:
You really do love your car...
Just a more detailed post of the tune day:
Picture of the dyno, you can sort of see the dyno graph in the rear. Graph stops at 4,500 rpm
So something was stopping the car from making power and taking timing on the day.
At first suspect cam timing or compression. But checked cam timing on the dyno, and did a compression test. ~175psi across all cylinders.
Spark plugs changed. Dropped the exhaust. But made no difference. Still stuggling to make more than 310rwkw
So Trent tried a run on e85 but it still had the same issue. Car only took about 12 degrees of timing normally about 20. Only bumped up power to 315rwkw @ 4,500rpm
It is a suspected faulty injector so off to get it checked.
Pulled the injectors out this morning. As we have a suspected faulty injector. A simple quick test shows they seem to be ok. But will be sent away for a more detailed analysis
1512602_794511637229864_952685532_n.jpg?
In prep for the Dyno. Scotty @ Scotty Customs did:
  • Turbo install
  • New fuel pump Walbro 460L/H
  • Metal turbo elbow, as a silicone one was a bit close to the manifold
  • New Return flow intercooler bend. As the old one was quite crap
Turbo Elbow:
1522609-794510817229946-498803603-o-7945
1546041_794510817229946_498803603_n.jpg?
Intercooler bend:
1606291-794510800563281-1125706382-o-794
12109_794510800563281_1125706382_n.jpg?o
Things to do over the next month:
1. Fix issue with car that is holding it back
2. Fix heater hoses touching manifold
3. Fit oil cooler
Tony. Get some steel zip ties for the heater hoses. Good shit
I don't think zip ties would work here. I think braided lines will need to be made and run it over the engine.
just realised you may be one of the only 300kw+ R34's to be using stock intake and airbox lol what a monster
Hrmmm Im sure there would be many out there!
Might need to do a sneaky mod and cut the bottom of the airbox and fit a pod with another intake down the track if it ever becomes a restriction
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
