  • Replies 57
I'm out. Extremely sore
went gym now im exhausted, sorry guys =[
Sorry I didn't make it to this one I was a bit tired after gym.
Thanks for the trophy from the 2012 show n shine :)
Hopefully ill make the next meeting.
Do you all, even lift? LOL!
Awesome photos Jamie!
Was a great night, congratulations to those that won an award. See you all next time! :D
My inferior photos haha
Haha! Thanks!
All good man!
Hey I stopped being a pussy and still came along.
I'm trying to lift lol
Yeah, at least you came down... LOL!
Missed again, our daughter had her first child Wed night :-) and i had to adjust my priorities.
So I guess I should change my nickname to gramps :-/ maybe get an evo 7 gt-a.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
