Hi all , stumbled upon another GTX BB turbo I didn't know about .
This ones called GTX3067R and externally looks like the compressor end of a GT2860RS but in the newer style T04B port shrouded 0.60 AR compressor housing .
It differs from the usual GTX compressor wheels in that its 10 rather than 11 bladed and at one site they reckon they decided to give up a little high pressure ratio performance for slightly better spool .
Garrett looks to be claiming ~ 400 450 Hp (300-337 Kw) from this "compact" turbocharger size .
This is a link to their Sema booth and about half way down is a pic and brief description of what it does . Note the V Band "mohawk" turbine housing which they say will be available in three AR sizes .
http://www.motoiq.com/magazine_articles/id/2780/pageid/5382/nerds-eye-view-sema-edition-2012-part-i.aspx
Numerically speaking 67mm doesn't look real big but I think Garrett is attempting to better the 71mm 6 bladed compressor normally found in turbos like GT2871Rs and GT3071Rs . I guess if they can do that with 4 more blades and 4mm smaller major diameter why not . Note the port shrouded compressor housing would be an essential part of GTX compressor performance .
Depending on how they spool and pump overall these may be the thing Garrett wanted with the GT3071R , more turbine / flow and hopefully better compressor performance .
One to watch , cheers A .
  • Like 1
Yep they have been around since late ish last year, I have mentioned them before but was overlooked... Wonder if it was taken as a typo? Reckon that they could be a really good thing on RB20s/SR20s or in twin form.
I may have read it somewhere and thought it was a GTX3076R typo . If you search images of these things you often get pics of GTX3076Rs with the larger E series comp cover and 11 bladed compressor , not hard to make the obvious mistake .
I think it could be a viable alternate for a HKS GTRS though the heavier GT30 turbine may make it a little laggier . I can believe that 400 Hp is possible with a GT30 turbine where its virtually impossible with a GT28 pair , particularly in 0.64 AR form .
A .
Pretty much agree, will make quite a bit more power than the GTRS... probably not build from basement quite as enthusiastic as GTRS but once it is on (which won't take much) I bet it will be hell l responsive.
This site has some interesting info and overlays comparing a range of GT and GTX compressor wheels inc the 67mm GTX one .
http://forums.subdriven.com/showthread.php?5933731-Garret-gtx-options&p=80430561
Note that the GTX3067 is the smallest GT30R comp options but it still uses a port shrouded version of the old T04B compressor housing . The GTX3071R and GTX3076R jumo up to the T04E sized compressor housing so we don't get to see the 67mm GTX wheel in the T04E comp housing .
This is again a bit like trying to compare GT2871R compressor performance with GT3071R compressor performance , the 28s used B housings where the 30s use E housings .
If aiming for around say 300 WKw the GTX3067R may fall a tad short and the GTX3071R be a tad over the top - if you wanted the broadest usable power range .
A .
I have no idea what to expect.
I don't know how people in Oz have fared with the GTX28 series turbos but someone local put a GTX2863R onto an SR20VE+T and made 301kw @ hubs on BP98 with full boost at 3500rpm - which is a hell of a result imho, even if the numbers wouldn't be so impressive on a DD (I would expect this to equate to >260rwkw still). Point of that comment is that at that rate the GT28 turbine housing would be becoming the limiting factor, I'm amazed they got that power and am wondering if it is due to the higher shaft speed the 63mm compressor would require to move that air allowing the turbine wheel to move more gas too or some other quirk of the combo. Fact is the 63mm compressor delivers way better than I would have expected - 301kw on that dyno is GOOD power so in hearing that result and the fact that it should be safe to assume the 67mm compressor will deliver more, and the GT30 hotside will let it clear it's throat with no issue whatsoever... so this turbo will actually make quite respectable power.
My opinion - this turbo should eliminate the GTRS/GT2871R from any consideration on RB25s. If someone wants to fit the smallest practical turbo on and still sensibly upgrade the stock RB25 turbo - this would be it.
My ears have pricked up.
This is not the 500whp I was aiming for as my long term plans for the SR, but this could be something rather potent none the less.
Lith a problem still exists in that aside from the HKS ones , think RB spec GT2530/2535/GTRS , no one really made a GT28 turbine housing with a T3 flange and sadly HKS only did it in 0.64AR and not 0.86AR .
What this means is no larger housing for RBs where the SR brigade have the 0.86 AR T28 housing .
I know I've looked before and in the 0.86 housing that NS111 turbine flows similarly to a GT30 turbine - in a 0.63 AR GT30 turbine housing .
I sort of wonder how a GTX2867R in a 0.86 turbine housing would compare to a GTX3067R in a 0.63 AR housing .
Anyhow I agree that for SR (T28 flange) people at least either a GTX2863R or GTX2867R is probably better and cheaper new than a HKS GTRS .
For the RB (T3 flange) people you either go GT30xxR or with either the HKS 0.64 or an OP6 housing .
I don't know if anyone ever bought a flange adapter and used Garretts 0.86 GT28 housing on an RB engine .
A .
This is a Garrett catalog that covers many of the GTX turbos inc the GTX3067R . Interesting side notes on the GTX2860/63/67 turbos and what a few racers have gotten out of them . I suspect its with highish boost levels .
http://www.turbobyga..._Catalog_V5.pdf
Yeah not too sure about some of those aftermarket turbine housings , some people think the material is just so so .
A .
Edited by discopotato03
Well if you can bolt a GT30 turbo up with a truck style T04B 0.60 AR compressor housing I'd say yes . The RB spec GTRS is similar but with the std sized inlet snout . The Garrett housing probably has a 3" inlet boss so you need something larger to match it . Also need a different exhaust flange/dump if you currently have the std Nissan type one which GTRSs also have .
Incidentally my dump is the one I got off Woolverine and its an open or bell mouthed one .
A .
A kind feller from the VW Vortex site ran some numbers and did a compressor map overlay of the GT2871R 52T comp wheel and the 67mm GTX compressor . Similar sorts of things though he thinks the complete GTX3067R in 0.63 turbine housing form may fall just short of 300 RWKW for an RB25 .
Basically not worth the turbo changeover price .
They suggest someone elses GT30 + 71mm billet wheel hybrid that they reckon fits in somewhere between the 67 and 71mm X wheels . Alternatively they suggest buying a GTX3071R through ATP and getting the 0.60 AR T04B comp housing rather than its usual 0.60 T04E one . Gut feeling is that GTX wheels were designed to be used with port shrouded comp housings fir a reason .
http://forums.vwvortex.com/showthread.php?5965002-Performance-differences-between-Garretts-GTX2867R-and-GTX3067R&p=80828050&posted=1#post80828050
A .
A guy in the Audi world (I think?) tried an HTA3073 out and felt it spooled at least as well as a GTX3071R - no dyno results for it as yet though, the only single turbo HTA3071 results I have seen are this:
http://www.seatcupra.net/forums/showthread.php?t=251783
Equates to 310kw @ wheels on pump gas....
I must add that it seems a good amount of the high power GTRs (and the workshops that produce them) seem to consider the HTA turbos as the units of choice for R35 upgrades, though a lot of the companies that sell them just advertise them as "custom Garrett"... one of the tuners said that all but 1 (or 2?) of the 8s R35 GTRs in the world are currently running FP HTA turbos. They are also very common in twin turbo form on Porsches :)
  • 3 weeks later...
Just of late I keep coming back to this turbocharger , I have been re-reading Mick os GTX3071R results and I keep wondering what the smallest Garrett GT30 turbo can do in a 0.63 AR IW T3 flanged rear housing . Garrett quotes 500ish I think .
I'd like to here some opinions on GT30s in the lil 63 housing particularly the more modest compressor wheel options . If those that tried GT3071Rs with this housing can give their opinions I'd appreciate it . Garrett didn't have a port shrouded 0.60 AR T04B comp housing at the time AFAIK and thats what may have caused a few surge and wastegating dramas .
Lithium I think you reckoned that this dryer should replace the GT2871Rs/GTRS on RB25s and my gut feeling is the same , I'm waiting still for some innitial results and if they look positive I might give one a whirl . I've been looking at that comp map and I think a good std engine can probably take 20-21 pounds of boost particularly if its infrequent .
Decisions decisions , cheers A .
Ooooooooh so now they pricked up aye I remember somebody mentioning this to you not that long ago? :P
  • 4 weeks later...
There is a twin turbo V8 S14 time attack car (using a 1UZFE - a bit like putting an RB25 in a Supra, but meh) using twin GTX3067R in the build at the moment in Oz apparently. That could be interesting.
I thought the Americans were all over putting aluminium V8 Chevs into S14s when SR20s and KA24s didn't cut the mustard . I6s put the weight a bit further forward particularly if it has an iron block .
Anyway links ?
Cheers A .
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
