  • 3 weeks later...
So... Looks like this will be up and running soon. Booked in for tune on Wednesday (11th).
Spec list as follows, will be interesting to see what it produces.
1994 S1 R33
~165,000 kms, unopened engine
Nistune ECU
GTX3067 w/ 0.82 A/R Garrett internal gate housing
Stock manifolds
Pod filter - Alloy pipe intake
Z32 AFM
Blitz return flow FMIC
Greddy Profec OLED boost controller
Nismo 740cc injectors
Walbro 465 pump
3" Custom stainless exhaust.
Hopefully all the required supporting mods are there to let this turbo do its stuff. Shame I didn't end up getting the 0.63 A/R housing as first thought, but now interested to see what it will do with the 0.82.
  • 1994 S1 R33
  • ~165,000 kms, unopened engine
  • Nistune ECU
  • GTX3067 w/ 0.82 A/R Garrett internal gate housing
  • Stock manifolds
  • Pod filter - Alloy pipe intake
  • Z32 AFM
  • Blitz return flow FMIC
  • Greddy Profec OLED boost controller
  • Nismo 740cc injectors
  • Walbro 465 pump
  • 3" Custom stainless exhaust.
Indeed - me too, it's quite a different setup to really anything else done on here and it may provide an interesting result. I have reservations about the 0.82a/r housing but there are ways it will potentially help it, too.
EDIT: Seems to be a time limit on when I can edit my posts...
For me it will be interesting to see how this compares with previous results of GT3071 with same turbine housing. It seems like GTX turbos flow about the same as next size up GTs, so GT3071 power with bit better response would be nice.
Trying not to get my hopes up too much.
Edited by M@&k
Yeah, don't get too ahead of yourself - though for what it's worth I think the expectations seem pretty realistic. I suspect it should have some hilariously usable power :) Look forward to hearing driving impressions of it when you get it back! Look forward to hear (hopefully) how it goes tomorrow
I have seen one review of a GTX3067R replacing a GT3071R in 0.63 housings and it spooled slightly earlier than the GT3071R .
To be fair these turbos use different compressor housings , T04E 0.50 AR for the 71R and T04B 0.60 AR and port shrouded for the X67R .
A .
Edited by discopotato03
Thats a bummer Mark looking forward to seeing your results :(
My guess is you will see around 250-260kw if your setup has a good exhaust and intake system.
Good luck & looking forward to your driving impressions :)
I think you should of gone the 3071 if you wanted more mate ;)
My car was well sorted and I only went 288kw knocked back to 278kw on around 23psi on quite a low reading dyno with the 3071 and you have 4mm less of compressor so dont know what that will equate to.. Apart from ALOT of fun as I think its gunna be all in around 3500 :)
Edited by Mick_o
You haven't really given much of an impression of how free flowing your exhaust is etc, so I'm going to be different - go out on a limb here and say just over 270rwkw is possible if all goes well - and if boost control isn't lazy and depending on dyno run rate, 1bar in the low 3000rpm range.
Again, all depends on quality of tune and parts, how well the dyno is set up, and how good my crystal ball is haha.
Mick_O's prediction is probably a realistic expectation to set, however - I wouldn't aim higher, I'm just being devil's advocate as I think >270kw is in the realms of possibility.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
